d16y7 turbo
Old Dec 21, 2007 | 02:22 AM
ekk41's Avatar
Default d16y7 turbo
Modified by ekk41 at 6:23 PM 3/11/2008
Old Dec 21, 2007 | 08:36 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: d16y7 turbo (ekk41)
https://honda-tech.com/zerothread?id=635014
this will get you close. it isnt a y7, but the only real differences will be throttlebody plumbing. g/l have at it.
Old Dec 21, 2007 | 09:36 AM
Autoworks's Avatar
The Y7 install is the same as the other SOHCs with the acception of the vertical throttle body. If you are using a kit made for the EX you will need to add a 90 degree piece to connect the TB to the upper charge pipe.
Also, if you are using a 92-00 Civic "colt on" kit then the DP will fall short of connecting to the stock exhaust of a 96-00 DX w/ a D16Y7.
You can probably find more detailed install pics at http://www.d-series.org or http://www.turbod16.com
Old Dec 21, 2007 | 04:55 PM
ekk41's Avatar
Default Re: d16y7 turbo (Autoworks)
Thanks for the help im going to delay the turbo install until tomorrowwww
Fallen86
May 13, 2005 11:15 PM
ososlow24
Apr 8, 2005 08:40 AM
integra36
Jun 28, 2003 09:01 PM
r7
Mar 5, 2003 06:02 PM
Teluan
Sep 1, 2001 08:18 PM
