Short Circuit?
Old Dec 20, 2007 | 10:56 PM
benji7288's Avatar
Default Short Circuit?
For the past week, my civic has been acting weird. When rolling from a complete stop, my car's light seems to fade away for a second then comes back. Also, my CD player turns off then on at the same time. What might be the problem?
Old Dec 20, 2007 | 10:58 PM
93egSLEEPER's Avatar
Default Re: Short Circuit? (benji7288)
might be an alternator not charging correctly.
Old Dec 20, 2007 | 10:59 PM
benji7288's Avatar
Default Re: Short Circuit? (93egSLEEPER)
Ok, do u think that the gas has to do anything w/ it?
Old Dec 20, 2007 | 11:02 PM
gas wouldnt really affect how the lights and stuff are unless it is idling down really low and dying. does it "ping" at all? what motor and what kinda gas?? alternator sounds like its the problem though.
Old Dec 20, 2007 | 11:06 PM
benji7288's Avatar
It's a B16A2, I add Valero Supreme gas. Not sure about idling really low because i've had this car for a year n have never noticed this problem.
Old Dec 20, 2007 | 11:08 PM
well its probably the alternator. do you have a volt meter handy to test the charge it gives off?
Old Dec 20, 2007 | 11:10 PM
benji7288's Avatar
I have a radar that only reads the battery charge. This problem only happens around 3 times a day.
Old Dec 20, 2007 | 11:16 PM
well if the alternator isnt charging correctly then your battery wont charge correctly either. i suppose you might be able to tell by checking the battery.
Old Dec 20, 2007 | 11:30 PM
benji7288's Avatar
well it reads 13.3 when driving but let's say when it's in neutral, it'll go down to 12.1
Old Dec 20, 2007 | 11:36 PM
well the battery is charged well enough then... how many miles on the alternator? might just be going out.
Old Dec 20, 2007 | 11:37 PM
benji7288's Avatar
not sure if it's just the one that came w/ it but it has 86,000
Old Dec 20, 2007 | 11:40 PM
well if itshas to be a the original then it probably needs replaced. no CELS? it has to be a charging issue.... does it start ok or do u havta crank on it?
Old Dec 20, 2007 | 11:57 PM
benji7288's Avatar
It starts ok, no problem w/ that
Old Dec 21, 2007 | 12:00 AM
hmmm well the only thing that comes to me is alternator..... so try and get a voltometer on it and see how well its charging. might just be a bad voltage regulator also. those are cheap and easy to fix.
Old Dec 21, 2007 | 12:01 AM
benji7288's Avatar
what should be the reading when checking the charge on it?
Old Dec 21, 2007 | 12:04 AM
thats i cant tell you...lol. try searching it on the forum with the "red search button"
TAZ95
Sep 8, 2010 12:58 PM
VTECROAR96typeR
Sep 9, 2009 06:03 PM
Kowalski
May 19, 2007 05:19 PM
b20integrapower
Dec 29, 2005 10:36 PM
JDMCRXTypeR
21
Dec 6, 2004 03:33 PM
