97 ek hatch with 93 si motor help
Old Dec 20, 2007 | 09:20 PM
drmatasano01's Avatar
Default 97 ek hatch with 93 si motor help
wuz good i am having problems with my idle on my hatch cant seem to find the problem helppppp its a 97 ob2 with a 93 si d16z6 ob1
Old Dec 21, 2007 | 03:49 AM
turbodx95's Avatar
Default Re: 97 ek hatch with 93 si motor help (drmatasano01)
be more specific. What exactly is it doing?
Old Dec 21, 2007 | 05:02 AM
JDM_SOHC's Avatar
Default Re: 97 ek hatch with 93 si motor help (turbodx95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodx95 &raquo;</TD></TR><TR><TD CLASS="quote">be more specific. What exactly is it doing?</TD></TR></TABLE>
u mean from all that info he provided your unable to give a clear hypothesis of what his problems could be..?? lol
Old Dec 21, 2007 | 05:50 AM
deckster333's Avatar
Default Re: 97 ek hatch with 93 si motor help (JDM_SOHC)
more info please
Old Dec 21, 2007 | 05:54 AM
B18C5-EH2's Avatar
Former Moderator
Loved
What intake manifold are you running?
What IACV are you running?
What ECU?
Any check engine codes?
Help us help you - provide more info.
Old Dec 21, 2007 | 06:42 AM
Default Re: 97 ek hatch with 93 si motor help (B18C5-EH2)
it has the d16z6 manifold
i am just not sure if the wiring is correct on the one of the valve control plugs on the ob2 harness it has 3 wires going in to one plug i dnt kno where that goes
Old Dec 21, 2007 | 06:43 AM
when then car is still i got the idle to calm dwn but as soon as i give it a little gas it starts to rev back n forth between 1200 to 2100 rpm thn it stops after i go over 2500 rpm not sure y
Old Dec 21, 2007 | 06:44 AM
i am runing on a stock ecu it used to be automatic so it still has that ecu should i replace it ?? if so which ecu is reccomended ??
Old Dec 21, 2007 | 07:56 AM
chicows18's Avatar
Sounds like IACV or maybe your throtle cable is getting stuck. Check and report. Also, had the coolant been bled?
Old Dec 21, 2007 | 08:17 AM
Default Re: 97 ek hatch with 93 si motor help (chicows18)
i think i found the problem the valve that gets the coolant on my harness has 3 plugs and on the manifold it has 2 and its not connected i believe the orange wire i was told to disregard and not to use it the other 2 are the ones i have to match anyone ever tryed this before???
Old Dec 21, 2007 | 09:52 AM
redb16coupe's Avatar
wat harness are you running? obd2? if so u need to change the intake mani, and dizzy. maybe some additional sensors but mainly intake to get it running properly, also get a obd2 to obd1 conversion harness and run a p28 on it it should run alot better you need to get rid of the auto tranny ecu
Old Dec 21, 2007 | 06:45 PM
Default Re: 97 ek hatch with 93 si motor help (redb16coupe)
ok ill try that where can i get a obd2-obd1 jumperharness n how much ??
Old Dec 21, 2007 | 07:10 PM
ebay or here on in the forsale forum the go from 50 to like 100 depends if new or used http://www.hondamarketplace.co...72927 this dude has one for 50 shipped... remember your gonna need a obd1 computer... preferably a p28
Old Dec 21, 2007 | 08:13 PM
slo_hatch's Avatar
it might sound stupid...but why didn't you just swap a d16y8 in it and wire vtec? that would have been MUCHHH easier. rather than crossing obd's. and that is probably your problem...obd-2 non vtec ecu running an obd-1 vtec motor? sounds a little confused. kinda like a transvestite hooker.
Old Dec 22, 2007 | 06:45 PM
Default Re: 97 ek hatch with 93 si motor help (slo_hatch)
lol yea i kno but the only thing is i aint got that amount of time and cash to get this car runing right i need it for werk n school so i got a used d16z6 for 300 complete cant beat that lol
ek_ct
Oct 22, 2014 06:33 PM
honda_luvr_2000
Oct 27, 2010 04:53 PM
Prod
Sep 29, 2004 03:50 PM
