b20vtec?
Old Dec 20, 2007 | 07:38 PM
Lsweez's Avatar
Default b20vtec?
does anyone know the highest comprossion ratio you can run on a b20 block with stock sleeves
Old Dec 20, 2007 | 08:06 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: b20vtec? (Lsweez)
Depends what fuel you plan on using.
Comp isn't the only thing that makes power...
You have to build to match your comp ratio you do understand this?
Old Dec 20, 2007 | 09:04 PM
cmasonrun's Avatar
Default Re: b20vtec? (***$nyper)
im at 12.8 with stock sleeves on my b20vtec
Old Dec 21, 2007 | 07:28 AM
night's Avatar
the cr is not everything in the pressure. your cams and tuning play the majority role.
Old Dec 23, 2007 | 05:12 AM
Lsweez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsweez &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know the highest comprossion ratio you can run on a b20 block with stock sleeves</TD></TR></TABLE>
o yea i defintely understand cr has to match be able to support your cams, but i just need to know whats the most cr i could run on stock sleeves in a b20 since there sleeves are weak.. or would i be better of just sleeving a gsr block.
Old Dec 23, 2007 | 09:02 AM
badboyr66's Avatar
Stock sleeves are fine.
https://honda-tech.com/zerothread?id=1555476
Old Dec 23, 2007 | 09:27 AM
b20vtech's Avatar
i have herd of 14+cr on stock sleeves
xxjonxx4
15
Jan 24, 2013 04:22 PM
hondaboyB18C1
10
Jan 8, 2007 04:52 PM
BigC-ivic
15
Nov 11, 2004 10:31 AM
joacim
Feb 3, 2004 04:00 PM
