WHY DOES MY ALL STOCK D16Y7 DO THIS< NON_VTEC AND REDLINING AT 7,500RPM(VIDEO)
watch 1st and 2nd gear. i thougt d16y7's redline at 6800. wut do u think. thanx
p.s it just has exhaust w/ no cat so i call it stock. it redlined this high be4 i put the exhaust on.
i'll post the video in a little bit. 4 some reason its not working.
http://www.youtube.com/watch?v=OLKhg4gAPeA&NR=1
Modified by 96hatchy at 11:10 AM 12/22/2007
it doesn't have to do with your engine, your ecu is what controls the rev limit.
just because your engine goes that high, doesn't mean your engine is going to handle it.
take it easy on the engine alright?
Could be a chipped ecu, but your y7 doesn't need to rev that high unless its built and tuned.
i knew the ECU controls the RPM's but i thought d16y7's r supposed to redline at 6,800. so i was asking if somebody knew something about this
The ECU controls everything about the motor. Everything, including the redline. It may be a faulty ECU, or a notoriously inaccurate factory tach.
Either way, I wouldn't go beating on it until I found out for sure.
It might be your tach. I have a ls swap in my 2000 ej8 and the rev limit is supposed to be right at 7200, well on a few occasions, i took it past, So i took aprt the ECU(square ecu???) and found no chipping. So using my fancy shmancy OBD2 maching i matched my RPM signal that i was showed to my tach, and now everything works in perfect harmony.
nahhh, i have a d16y7 in my 00 LX with a 00 SI tranny swap and i redline at around 7500rpm also, BUT it sounds like a lawnmower on steroids and id rather not have it blow apart haha, but yes they do go up that high
i had a 96 civic ex before, tached at 7200...blew the tranny, so i put another tranny in with a 7 pound fidanza flywheel and it tached at 7500...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19ekcoupe96 »</TD></TR><TR><TD CLASS="quote">how do u have a b series tranny on ur d series motor????</TD></TR></TABLE>In canada the 96-00 coupes were called si's. They still had the d series in them.
I think the OP is confused between the two terms redline and revlimit or maybe I just didn't read it correctly. The redline is 6800rpm which is correct. The revlimit SHOULD be 7200rpm. Usually with any car you can go past the redline but it's not going to be making anymore power unless there is more work done to the motor.
Cool Cool Island Breezes. BOY-EE
could just be a tach that's off by a bit. Stock rev limit should be around 7k-7200ish.
Why no cat?
Why no cat?
the stock tach is off by a few, my stock dx hatch revd up to 7200 too until i had a rod knock on rod number 1...take it easy unless you have moolas to replace that stock motor of yours...****...take care of that motor man...drive safe...
stock tach is off...
btw.. DAYMN them some long *** gears.. **** im at 80 5th gear at 4800rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a »</TD></TR><TR><TD CLASS="quote">the stock tach is off by a few, my stock dx hatch revd up to 7200 too until i had a rod knock on rod number 1...take it easy unless you have moolas to replace that stock motor of yours...****...take care of that motor man...drive safe...</TD></TR></TABLE>
My d16y8 spun a rod bearing too lol. It was definitely from reving high and the fact that I had low oil. I could feel it gradually getting slower and finally the knocking started. I still drove it for a month with the rod knock just didn't rev it too much. I had my b18b on order so I didn't care too much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">stock tach is off...
btw.. DAYMN them some long *** gears.. **** im at 80 5th gear at 4800rpm</TD></TR></TABLE>
that sounds like a very very low gear. Lower than the B16A. The stock B16A is at around 4500ish at 80.
The Y7 trans puts you at around 3k @ 100mph.
OP you should have no problems revving the engine to stock fuel cut all the time.
im sure its a y7 ECU and i have a factory LX cluster so i doubt its off. and it still makes power until 7500.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hatchy »</TD></TR><TR><TD CLASS="quote">im sure its a y7 ECU and i have a factory LX cluster so i doubt its off. and it still makes power until 7500.</TD></TR></TABLE>
They're all off - usually not that bad though.
@ OP:
What kind of rims/tires are you using?
Your gear ratios / speeds are horribly off. Should be at 70mph @ 6700-6800 RPM in a D16Y7 transmission, so this means one of two things:
A) You changed the tire size and it threw off your speedometer reading (likely)
B) Your tach is simply 1000 RPM off. (verrry likely)
C) Somebody changed out the gear ratios in your D16Y7 transmission and put custom ones in there (VERY unlikely)
Just for ***** and giggles, what's your tire size?
@ OP:
the stock rev limit is at 7200 rpms. i bounced off mine one time in my dx and it read around 7700 rpms.
its just tach inaccuracies
