car feels like its going to turn of. 1994 accord lx
Old Dec 20, 2007 | 01:04 PM
jose310's Avatar
Default car feels like its going to turn of. 1994 accord lx
wen i brake at a stop light hard, the idle goes a down and the car vibrates and then the idle goes back up to normal, also wen im in reverse the idle will sit low, and feel vibration. also at idle the steering wheel vibrates and it rattles a bit, is it time for new spark plugs? or any ideas?
Old Dec 20, 2007 | 01:42 PM
two_brothers_racing's Avatar
Default Re: car feels like its going to turn of. 1994 accord lx (jose310)
check the alternator the brakes maybe using more power with other stuff than the alternator can handle if it is the alternator try using a bigger amp alternator
Old Dec 20, 2007 | 02:53 PM
NeKe1point0's Avatar
its kinda hard to help without some info on ur car... auto/manual etc.
its poss it could be something as simple as ur tranny mount if its an automatic...
provide more info for better feedback
Old Dec 20, 2007 | 04:11 PM
jose310's Avatar
Default Re: car feels like its going to turn of. 1994 accord lx (NeKe1point0)
my bad, its a auto, wat can make the steering wheel vibrate and rattle a lil in the dash?
Old Dec 20, 2007 | 04:49 PM
hondadude's Avatar
Clean the throttle body/ throttle plate area,[toothbrush and Berrymans B-12] put in some good fresh spark plugs.
Consider removing the IACV and blasting it out with some Berrymans B-12 and compressed air.
Look at the tach when you are in drive with the brake on and tell us what number the needle is pointing to.
The front subframe "dog bone" motor mount has a little adjustment on it.
Old Dec 20, 2007 | 05:04 PM
jose310's Avatar
Default Re: car feels like its going to turn of. 1994 accord lx (hondadude)
at idle with me on the brake its a lil under the 700-750? line , and about the motor mount, do you think that can be the problem? i had a friend check it out and he said it can be the motor mount and its a easy job.
Old Dec 20, 2007 | 05:35 PM
cb7tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jose310 &raquo;</TD></TR><TR><TD CLASS="quote">at idle with me on the brake its a lil under the 700-750? line , and about the motor mount, do you think that can be the problem? i had a friend check it out and he said it can be the motor mount and its a easy job.</TD></TR></TABLE>
It could be a motor mount, but you should also consider what Hondadude said you should do.
Old Dec 20, 2007 | 05:36 PM
hondadude's Avatar
Look at the mount, see if the rubber bushing is cracked/broken.
engine running trans in park/neutral loosen then retighten the top mount bolt; see if it changes the vibration problem.
Better to have vibration in reverse than Drive
Your idle speed is about normal, but cleaning the IACV and throttle plate improves idle quality.
Old Dec 20, 2007 | 06:01 PM
jose310's Avatar
IACV? sorry im new to the honda scene, , i could use carb cleaner on the throttle body right?
Old Dec 21, 2007 | 04:21 AM
IACV- Idle air control valve
FITV- fast idle thermal valve
TB - throttle body
hondadude was def right about inspecting these to start. very well could be anyone of the above 3. id say inspect/clean these 3 to start, its easy and cheap to maintain and really makes the car run alot cleaner. id say do it anyway especially if you havent in a while or ever. there is a DIY link in the FAQ section.
but......I will bet u its the mount like i originally posted. im gonna go with $20 on the rear mount and $10 on the front, they receive the most abuse. GL and lets us know what the fix was
oakpwr
Sep 15, 2008 06:28 PM
01hondaccordlx
May 28, 2008 04:01 PM
djkdawg
Sep 27, 2006 02:45 PM
Makdaddynuge
Jun 16, 2005 07:31 AM
vcolfari
Jul 2, 2004 11:13 AM
