Need Help:REF won't allow jumper harness(crx/b16)
Old Dec 19, 2007 | 08:20 PM
66fasty's Avatar
Default Need Help:REF won't allow jumper harness(crx/b16)
Long story short my REF out here wont allow a jumper harness for an OBD 0 to OBD 1 conversion.I just need confirmation on my parts list.
92-95 Civic V-tec engine harness
92-95 Civic under dash harness(including ECU harness)
USDM P30
Will the OBD 1 dash harness just plug right up to the CRX's interior plugs?If i completely swap out both the engine and dash harness' will I be good to go? O r should I just add OBD1 plugs to my OBD 0 harness?
Thanks
Old Dec 20, 2007 | 04:12 AM
StorminMatt's Avatar
Default Re: Need Help:REF won't allow jumper harness(crx/b16) (66fasty)
Do yourself a HUGE favor and don't try to run a complete 1992-1995 harness in your car. Just solder 1992-1995 ECU plugs on your stock harness. MUCH, MUCH easier.
Old Dec 20, 2007 | 05:56 AM
66fasty's Avatar
And that would still pass as OBD1?the car is already running as OBDO,So if I take off the resistor box,change the ECU plugs to OBD1,and change all the engine harness plugs I should pass. What about the service ports on the OBD1 harness(where you use a jumper to check codes) he requires those
Old Dec 20, 2007 | 04:53 PM
66fasty's Avatar
TTT
Old Dec 20, 2007 | 05:05 PM
Default Re: (66fasty)
This has always worked for me. On the other hand, before you do ANYTHING, you should try going to a different referee. Some are just more nitpicky than others. I had one referee give me problems because I left the diagnostic port in the engine bay rather than under the dash. But I ended up taking it to a completely different station, and it passed. So you might be able to pass it even with your jumper harness if you just go somewhere else.
Old Dec 21, 2007 | 08:49 PM
66fasty's Avatar
Anyody else have any input?
alexpr
Jun 6, 2010 03:40 AM
civicex442
Dec 2, 2007 07:38 AM
hybrid1990crx
Oct 15, 2007 03:34 PM
dizzyek
Feb 9, 2006 01:50 PM
teefunk01
Mar 31, 2005 04:24 AM
