B18a1 into 89 CRX HF
Ok, I have a few questions about the swap..
First I need to know if these mounts look right...this is my first swap and these came with the car.
I also don't understand how the L shaped one works and where it goes.
I also need to know what bolts here on the back of the block. Is it the alternator?
And here on the front
And finally where is the best place to buy bolts for the mounts, bolting the trans to the engine, and everything else. The big problem is I don't know what size to buy for any of them because none came with anything.
Thanks
Thanks
ok what you need to do is scroll to the top of this thread and look in the right hand corner. about an inch and a half - two inchs from the top right hand corner will be some red text. if you click that link you can find out all sorts of super neat stuff. i promise.
goodluck
buuuuut since im nice...
L bracket is the rear mount connection between the engine assembly to the mount located on the rear crossmember. the front shot you showed asking what bolts here thats the air conditioner compressor if you dont have A/C dont worry about it and the rear shot you showed is for the alternator lower bracket you were right.
goodluckbuuuuut since im nice...
Chief Wenceslaw
21
Sep 4, 2006 04:57 PM
Moon Ill
Jun 16, 2005 04:23 AM
crx_soldier
May 23, 2005 08:35 PM
dipillo
May 1, 2005 01:11 PM
Hulkbuster
11
Feb 3, 2003 12:34 PM
