K20a into EG Wiring write up
what do you want to know?
engine harness 02-04 rsx, rewire crank angle if using 2-4L
charge harness fromsame car, and a hybrid racing/hasport conversion harness. you can make your own out of your old harness (main) but i suppose its out of the question if you can't really do the wiring with ready made kits.
also if you want to run the DIY reflash thats coming soon VERY soon (if hondata doesnt sue us TOO! ) you need to remove where the factory ecu plugged in also and rewire for the k sreies ecu and you have to wire in an DLC so that the HIM can burn the new map for you. but thats in the future for now, you can either run k pro or a k20-r ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos »</TD></TR><TR><TD CLASS="quote">You mean the pnp harness wiring? Or the wiring of the motor?</TD></TR></TABLE>
i think he means the PNP harness
Camoef9
Apr 7, 2003 07:25 PM
