A little help please (injectors)
So I bought a car with a b-series swap. It originally had RC 370cc injectors in it. I took them out...bought some stock b-series injectors and put them in. I went to put the clips on and they dont fit. I'm certain these are both B-series and OBD1, which is why i'm confused. If someone can take a look at these pictures and help me out that would be great.
These are another set of injectors I have in my garage that also dont fit, but are also different then the ones from above. What are these? Cause I thought these were obd2 and the ones above were obd1. Does someone have a picture of OBD1 injectors then? So I can make a comparison.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 007EG »</TD></TR><TR><TD CLASS="quote">
Snip the center section out. Make sure those are obd1 and not obd0 as they are difference resistance injectors (obd0 require a resistor box).
So are those OBD0 or OBD1 then? I'm certain that the second pair of injectors I have on my 3rd post are OBD2. So how do you tell if that first pair are obd0 or obd1?
injector clips are different, from obd0 to obd1. i think thats the only way you can tell, that or an ohm tester. but they look to me like obd0. my Rcs are sittin right here and they look identicle
im sure you can find one on honda tech, if not go through a junk yard you'll find something its 5 wires total. power in, and 4 wires out go to each injector. if all else fails 80 bucks new from honda
Acura_I-RS
Apr 11, 2003 08:21 PM
