86mm gives how many HP over stock 81mm's
Old Dec 19, 2007 | 04:51 PM
bignewtCA's Avatar
Default 86mm gives how many HP over stock 81mm's
im not too sure if the sleeving the block with bigger piston will dramatically increase horsepower.
have anybody gotten major horsepower out of this?
dyno?
Old Dec 19, 2007 | 04:56 PM
4dooritr's Avatar
Default Re: 86mm gives how many HP over stock 81mm's (bignewtCA)
yeah... if it didnt gain nothing why would people go with higher displacement?
usally gain more mid-range and torque
Old Dec 19, 2007 | 05:37 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bignewtCA &raquo;</TD></TR><TR><TD CLASS="quote">im not too sure if the sleeving the block with bigger piston will dramatically increase horsepower.
dyno?</TD></TR></TABLE>
How are we supposed to be able to answer this question for you? Whats your definition of "dramatically"? 86mm is quite a bit larger over 81mm. Common sense says the more volume you can fit in the cylinder the more power it will develop. No one here is going to be able to tell you "You will get 54hp @ 2643rpms"... so don't bother asking.
Old Dec 19, 2007 | 09:33 PM
toyomatt84's Avatar
Sanji
Default Re: 86mm gives how many HP over stock 81mm's (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">How are we supposed to be able to answer this question for you?</TD></TR></TABLE>
Simple: you're not.
Rules:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">4) E-Racing/Bench Racing/Guess my 1/4 or HP
There is no place for it here, it is not productive, frequently leads to arguments, and is generally pointless. Go find a dyno or a drag strip.</TD></TR></TABLE>
jprelude92
Jan 8, 2008 01:57 PM
HondaPH22
Honda S2000
20
Oct 5, 2006 12:29 AM
phil34653
Sep 5, 2005 04:41 AM
whytTypeR
Feb 17, 2005 08:29 PM
