Type R Trim Level (1996–2001 Excluding 1999)
Old Dec 19, 2007 | 03:25 PM
Boosted_01 R's Avatar
Default Type R Trim Level (1996–2001 Excluding 1999)
The Type R was the pinnacle of the Integra line. It had many exclusive features found on no other Integra. This trim of the Integra only had a 5 speed manual transmission as standard.
The Type R's B18C5 engine contained more key differences than just some manual assembly steps and an increased redline. The B16A's cylinder head returned, with differently shaped combustion chambers and intake ports compared to the regular B18C in the GS-R. Molybdenum-coated, high compression pistons and stronger-but-lighter connecting rods strengthened the reciprocating assembly. Extra counterweighting on the crankshaft altered its vibration modes to enhance durability at high RPM. The intake valves were reshaped with a thinner stem and crown that reduced weight and improved flow. The intake ports were given a minor port and polish. Stiffer valve springs resisted float on more aggressive camshafts. Intake air was now drawn from inside the fender well, for a colder, denser charge. That intake fed a short-runner intake manifold with a larger throttle body for better breathing. An improved stainless steel exhaust collector with more gentle merge angles, a change to a larger, consistent piping diameter, flared internal piping in the muffler allowed easier exit of gases. A retuned engine computer also contributed to improved power output, which allowed the Type R to accelerate from 0 to 60 mph (100 km/h) in 6.2 seconds.
The transmission was upgraded with lower and closer gear ratios in second through fifth gears, in order to take advantage of the additional rev range. The North American version retained the same 4.4 final drive throughout the Type R's production run, unlike the Japanese version, which in 1998 changed to a 4.785 final drive along with revised gearing. The GS-R's open differential was replaced with a torque-sensing limited slip type.
The chassis received enhancements in the form of reinforcements to the rear wheel wells, roof rail, and other key areas. "Performance rods", chassis braces that were bolted in place, were added to the rear trunk wall and rear subframe. The front strut tower bar was replaced with a stronger aluminum piece. Camber rigidity was improved at the rear by increasing wheel bearing span by 10 mm. The Type R's body also received a new functional rear spoiler, body-colored rocker panels, and 5-bolt hubs with special lightweight Type-R wheels. Under those wheels was a much larger set of disc brakes, front and back. The tires were upgraded to Bridgestone RE010 "summer" tires.
The Type R received very aggressive tuning in its suspension settings. All soft rubber bushings were replaced with much stiffer versions, as much as 5.3 times higher in durometer readings. The springs and dampers were much stiffer, with a 10 mm (0.4 in) reduction in ride height. The rear anti-roll bar diameter was increased to 22 mm (0.9 in) in diameter. The front anti-roll bar retained the same size, although the end links were changed to a more responsive sealed ball joint as opposed to a rubber bushing on the lesser models. The result was a chassis with very responsive, racetrack-ready handling that ably absorbed mid-corner bumps. Mild oversteer was easy to induce with a lift of the throttle, and during steady-state cornering the car maintained a slight tail-out stance.
The interior was stripped down to reduce weight. The air conditioning system was removed in early models and nearly all the sound-dampening material was eliminated. This provided for a much noisier ride, but since the Type-R was marketed as a race car for the street, most owners didn't mind.
---->Just though it it was some good information, It would have made it easier wondering whats was so different from a normal Integra. Also I learned some stuff about my R
Old Dec 19, 2007 | 03:29 PM
Default Re: Type R Trim Level (Boosted_01 R)
BTW Not sure why this info excludes 1999 R's
Old Dec 19, 2007 | 03:30 PM
white rocket's Avatar
<-----feels left out
The ITR was not offered in the US in 1999. Everyone else, including Canada, got it that year though.
xtreme26's Avatar
you realize this forum is about 8 years old right, wasn't made yesterday
Old Dec 19, 2007 | 03:45 PM
4LugR's Avatar
Default Re: (xtreme26)
^ this guy stole my avatar from like a year and a half ago!!!!
thats ok tho..
Old Dec 19, 2007 | 03:46 PM
00TypeR1071's Avatar
hmmmm..........you are few years late
Old Dec 19, 2007 | 05:44 PM
jordanitr's Avatar
hmmmm..........you are few years late [/QUOTE]
My thoughts exactly
Old Dec 19, 2007 | 05:47 PM
crxgator's Avatar
Default Re: (jordanitr)
how many type r's were made?
what's the difference between jdm and usdm type r's?
can i make my RS a type R by swapping parts?
Old Dec 19, 2007 | 06:02 PM
pvt_awol's Avatar
Default Re: (crxgator)
I dunno, still kind of nice to read aRticles every so often.
Old Dec 19, 2007 | 08:52 PM
nautica_t's Avatar
looks like a wikipedia copy and paste lol
Old Dec 19, 2007 | 09:04 PM
Default Re: (nautica_t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautica_t &raquo;</TD></TR><TR><TD CLASS="quote">looks like a wikipedia copy and paste lol</TD></TR></TABLE>
Yes it was, gotta admit, its pretty good info.
Old Dec 20, 2007 | 12:56 AM
actionanh's Avatar
Default Re: (Boosted_01 R)
Old Dec 20, 2007 | 02:37 AM
fourcsan's Avatar
* B A N N E D *
thanks for reposting that. always nice to shove some info onto anyone trolling about. all the real facts are usually quickly buried by "whats this noise" and " new photoshoot" threads. although those are also my favorite threads.
Old Dec 20, 2007 | 11:40 AM
zygspeed (former)'s Avatar
Here's a link from ... way back:
http://autopedia.com/Acura/97_TypeRPress.html
Once there, the alternative links/headings at the bottom of the page still seem to work. Ed
Old Dec 20, 2007 | 12:35 PM
Alex_G's Avatar
Occupy GDD
Default Re: Type R Trim Level (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">&lt;-----feels left out
The ITR was not offered in the US in 1999. Everyone else, including Canada, got it that year though.</TD></TR></TABLE>
Sorry off topic but never figured out the answer to this? Why wasn't it offered searched here, google, etc and I couldn't find a definete answer.......
Old Dec 21, 2007 | 04:13 PM
fourcsan's Avatar
* B A N N E D *
same reason we didn't get 16"s. because everyone hates USA!
RataBlanca
Aug 17, 2002 01:00 PM
