Wiper arms
Old Dec 19, 2007 | 02:34 PM
HubeyHatch_EK's Avatar
Default Wiper arms
I found that the wiper arms on my ek were striped so i need new ones i have a friend that has a pair of eg arms will they work? i did search but didnt find any about eg arms on ek any help would be great thanks
Old Dec 19, 2007 | 02:38 PM
Default Re: Wiper arms (HubeyHatch_EK)
annnyyonnnee
Old Dec 19, 2007 | 02:46 PM
NOFX's Avatar
H-T White Ops
Hold them up to figure out if they're the same size and if they are try to fit them on. Then test.
please help
Old Dec 19, 2007 | 02:47 PM
93egSLEEPER's Avatar
what is stripped on them?? the paint?
Old Dec 19, 2007 | 02:48 PM
Default Re: (NOFX)
man you are helpin me out thank you btw it went ok happy it was just the arm but then ore problems arose, we ended up workin on stupid **** till one haha
Old Dec 19, 2007 | 02:49 PM
Default Re: Wiper arms (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">what is stripped on them?? the paint? </TD></TR></TABLE>
The thing under the bolt idk the name no more thread on the arm
Old Dec 19, 2007 | 02:50 PM
NOFX's Avatar
H-T White Ops
That's right... how can your wiper arms strip out? They're not really threaded. The nut that goes on top of them are though. Are you sure they were tight enough?
Old Dec 19, 2007 | 02:51 PM
Default Re: (NOFX)
the thing under the arm?? like the nut thread? that is attached to a motor so ud have to replace that instead of the arm. you cant strip the arm...
Old Dec 19, 2007 | 02:52 PM
Default Re: (NOFX)
well not threaded but after we took the motor cover we saw like shavings from the arm hmm ill go try to put them on very tight to see if it works
Old Dec 19, 2007 | 02:54 PM
Default Re: (HubeyHatch_EK)
if the nuts isnt tightened down all the way it wont give enough pressure to the wiper arm causing it to not wipe correctly
Old Dec 19, 2007 | 03:01 PM
NOFX's Avatar
H-T White Ops
Yeah, the wiper seems to mostly be held in place by pressure of the nut on the linkage, not a thread on the arm.
So if there's anything that's stripped, it's either the nut or the linkage. Replacing the linkage is basically the same as replacing the motor.
Old Dec 19, 2007 | 03:10 PM
Default Re: (NOFX)
Wow i feel very stupid i did it very tight and they seem to work now thank you guys so much for the help i appreciated it
Old Dec 19, 2007 | 03:11 PM
no problem... happened to me before.
da6er
Apr 10, 2008 06:43 PM
jnick
Feb 13, 2008 07:48 AM
ej1serge
Aug 15, 2007 12:17 PM
R6Elmo
Aug 19, 2003 01:24 PM
MugenGTR
Apr 21, 2003 06:45 AM
