parked 2000 accord bouncing idle when not in gear
Old Dec 19, 2007 | 09:45 AM
361 accord's Avatar
Default parked 2000 accord bouncing idle when not in gear
i had my 2000 accord EX sedan in the garage for a few months while i was in college since i slammed into a curbed and $%#^ed up the alignment , now starting it back up, it starts up just fine, but then it started having the "bouncing idle" that goes from 1250 to a little over 2000 rpm its not a fluctuating idle it bounces like its hitting the rec limiter
also there was some smoke coming out oif the exhaust
anyone got any ideas
the fuel in the tank is pretty old, about 4months
Old Dec 19, 2007 | 10:52 AM
trev0006's Avatar
* B A N N E D *
check to see if all pistons are working, you could have a faulty plug.
cheap tires cheap wheels cheap brakes cheap suspension cheap car tires motorcycle race
Modified by trev0006 at 1:17 AM 6/12/2008
Old Dec 19, 2007 | 11:46 AM
361 accord's Avatar
Default Re: (trev0006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trev0006 &raquo;</TD></TR><TR><TD CLASS="quote">check to see if all pistons are working, you could have a faulty plug.</TD></TR></TABLE>
im not sure how to tell if all the pistons are working...and the plugs were fine when i parked the car
but what the hell i suppose i can check them anyways
anyone else think if could be one injector running nasty, or if theres a DIY for cleaning injectors
Old Dec 19, 2007 | 12:16 PM
Mcdc2's Avatar
Default Re: parked 2000 accord bouncing idle when not in gear (361 accord)
Wow man I wish I could help you but I'm just as stumped as you are
Old Dec 19, 2007 | 02:11 PM
scabbs's Avatar
Default Re: parked 2000 accord bouncing idle when not in gear (Mcdc2)
maybe an idle air control valve?
Old Dec 19, 2007 | 02:16 PM
TheMuffinMan's Avatar
He knows where you live!
check the FITV/IACV/TB etc
and clean all that.
Old May 16, 2008 | 08:06 PM
anoparticular's Avatar
New User
take the idle air control valve off, take it apart, it will have a plunger looking thing in it, it has a big round screw around it, hold the plunger down, and turn the screw clockwise until the plunger is all the way back down, then put it back together and put it back on... take the negative cable off the battery for 5 minutes, put it back on and start the car and that should solve the problem...
Old May 16, 2008 | 08:25 PM
361 accord's Avatar
actually it solved itself, when it was in the shop for hittin the curb, i guess they fixed it or goodyear did when they changed oil idk i wasnt there
my mom did it all for me oh well free **** for me
Jobables
May 24, 2013 04:23 AM
hondaccord00
Jun 30, 2010 06:04 AM
shadetree14
Sep 20, 2009 09:16 PM
thenderson22603
Aug 11, 2008 06:59 PM
