Spark plug gap?
Old Dec 19, 2007 | 08:08 AM
layn22s's Avatar
Default Spark plug gap?
I got some platinum plugs from auto zone yesterday and he said just to put them n since they are the platinum they dont need to be gapped? Is this true?
Old Dec 19, 2007 | 01:39 PM
Perfectionist's Avatar
Default Re: Spark plug gap? (layn22s)
Maybe you misunderstood, or the guy is a moron. Spark plugs need a gap to fire across. The size of the gap is indicated on the emissions lable under the hood or in the owner's manual for your vehicle. Probably what he meant was, platinums and some others come pre-gapped for your application. A small cardboard sleeve around the firing end of the plug would imply this. It is always a good idea to double check the gap before installation.
Old Dec 19, 2007 | 04:22 PM
layn22s's Avatar
Default Re: Spark plug gap? (Perfectionist)
what should my plugs be gapped to. I have a 00 Civic SI DOHC v-tec..prolly dont matter but got a cheap cold air intake and magna flow muffler.
Old Dec 20, 2007 | 02:47 AM
layn22s's Avatar
??anyone know??
Old Dec 20, 2007 | 04:44 AM
Mikey3000's Avatar
.030-.035
Old Dec 20, 2007 | 04:37 PM
layn22s's Avatar
I just checked them yes they do have a cardboard sleeve around them.
Old Dec 26, 2007 | 02:55 AM
layn22s's Avatar
When I put my new plugs in sat., the old ones that i took out were gapped to .056!
Old Dec 26, 2007 | 05:53 AM
aca's Avatar
aca
you should go w/ some denzo or ngk iridiums instead. much better plugs and they are oem. working at a shop ive seen cars come in running just fine and missfire like mad after we put in some platinum 4 plugs in.
Old Dec 26, 2007 | 08:22 AM
KevinT707's Avatar
Stick with the $1-$2 NGK spark plugs, they're inexpensive and do the job well. I don't know what motor your spark plugs are going in but the gap is most likely a .044.
Old Dec 26, 2007 | 08:27 AM
layn22s's Avatar
Default Re: (KevinT707)
STOCK 2000 SI CIVIC
Old Dec 26, 2007 | 03:18 PM
aca's Avatar
aca
the reason i say iridium plugs is because they last longer without problems. That being said, if you are like me you will change your spark plugs more often than you need to anyway, so that migt be a good bet. Ive never ran the regular ngk plugs so i cant tell you how they do. im pretty sure a b16 calls for iridiums however. could be wrong.
Old Dec 26, 2007 | 04:18 PM
96 GSR-T's Avatar
not stock here, .016 gap ftw lol
Old Dec 27, 2007 | 03:50 AM
layn22s's Avatar
Default Re: (96 GSR-T)
auto zone showed to run platinum take that for what its worth lol
ZXiPoZ
May 3, 2012 09:25 AM
bringmyownend
May 4, 2007 07:41 PM
silvercivicsir
Feb 18, 2002 02:36 AM
keys
Aug 8, 2001 07:52 AM
