00 engine noise
Old Dec 19, 2007 | 07:20 AM
PhrequenC's Avatar
Default 00 engine noise
my engine makes ALOT of noie for some reason.. only after about 2500rpm or so with the clutch engaged. i never noticed it before with my n1. but when im driving, it sounds normal and then gets really loud.. i really cant explain it well and im not sure if i a video will help, but ill take one and see what happens.
d16y8
Modified by PhrequenC at 10:07 AM 12/19/2007
Old Dec 19, 2007 | 07:39 AM
PhrequenC's Avatar
Default Re: 00 engine noise (PhrequenC)
ok i went to take a videos but you cant hear anything..
Old Dec 19, 2007 | 01:22 PM
PhrequenC's Avatar
could it be axles or clutch?
Old Dec 19, 2007 | 01:34 PM
CtREK9's Avatar
What kind of noice is it what does it sound like it could be several different things
Old Dec 20, 2007 | 08:25 AM
PhrequenC's Avatar
Default Re: 00 engine noise (CtREK9)
i really dont know.. its not a throw out bearing becuase it doesnt make it when the clutch is down its when its enganged
Old Dec 20, 2007 | 09:24 AM
yoej8's Avatar
try n describe the noise. is it scratchy, squeely, knocking, etc
Old Dec 20, 2007 | 09:48 AM
wiZCo's Avatar
Stouts 'n' Scotch
Does it get louder as you go up in RPMs in gear?
If so, it could be a bad input shaft bearing.
Old Dec 20, 2007 | 10:00 AM
PhrequenC's Avatar
Default Re: (wiZCo)
it sounds like a grinding noise. it doesnt gget louder or quiet with rpm. its pretty much the same sound throughout the rpm
Old Dec 20, 2007 | 10:48 AM
chicows18's Avatar
Default Re: (PhrequenC)
its just you...........the noise in is your head.....jk.............but seriously, there is no way for people to help if you cant describe it in detail and also would help for you to OPEN the hood and listen to see where its coming from.
Old Dec 20, 2007 | 12:55 PM
PhrequenC's Avatar
Default Re: (chicows18)
its only wen im driving.my friends dad said its def coming from the trans.probaly a bearing he said.
Old Dec 20, 2007 | 01:06 PM
SpeedoKing's Avatar
that would be my guess if it is a whining or grinding.
Old Dec 20, 2007 | 02:35 PM
hplssone's Avatar
Default Re: (yoej8)
i would say throw out bearing
Old Dec 20, 2007 | 02:37 PM
hplssone's Avatar
Default Re: (yoej8)
when the clutch is down the pressure from the load on the bearing stops the noise so it will only do it when the clutch is out and does not matter if it is in gear or not
Old Dec 20, 2007 | 08:13 PM
PhrequenC's Avatar
Default Re: (hplssone)
false. my friend had a bad throw out bearing on his mustang gt, and it made noise only when the clutch when pressed DOWN to the floor while shifting gears
Old Dec 21, 2007 | 09:33 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhrequenC &raquo;</TD></TR><TR><TD CLASS="quote">false. my friend had a bad throw out bearing on his mustang gt, and it made noise only when the clutch when pressed DOWN to the floor while shifting gears</TD></TR></TABLE>
Right. The TOB will show signs of failure when the clutch is depressed, not engaged. If it's making the noise at speed ONLy when the clutch is engaged, my first guess (again) would be a bad input shaft bearing. It's a common problem on these Honda transmissions, especially if they have a lot of miles on them. The ISB in my 75K mile S4C trans is already starting to make a little noise.
Old Dec 21, 2007 | 10:34 PM
PhrequenC's Avatar
Default Re: (wiZCo)
ive got about 85k.. so i might be what oyu say it is.
where can i order a new one ISB?
Old Dec 22, 2007 | 07:19 AM
wiZCo's Avatar
Stouts 'n' Scotch
http://www.hondaautomotiveparts.com
Although, it's still possible that it could be an axle issue as well. You may just want to get it checked out because if you're not planning on doing the ISB yourself, prepare to bend over.
Old Dec 22, 2007 | 09:05 AM
PhrequenC's Avatar
Default Re: (wiZCo)
hahah absolutely not. my friends dad is putting it on the lift to test it out first.
1clean01
Honda Civic (2001 - 2005)
May 2, 2012 08:11 PM
usdmed9
May 17, 2011 10:46 AM
white_db8
Oct 14, 2009 04:16 PM
ufakeit
Sep 5, 2009 04:21 PM
EsQueue
Jul 5, 2004 12:00 AM
