fuel pressure flow ratio
Old Dec 19, 2007 | 05:43 AM
civickid03's Avatar
Default fuel pressure flow ratio
i bought a b16 with skunk2 stage 2 cams and valvetrain but the guy has stock injectors. fuel pressure is set at 56psi at idle and leaned out the upper portion of the fuel map with a VAFC. I need to get the car properly tuned but I need to drive it as my daily. Should i reset the VAFC and lower the pressure? What do other people with the cams run with stock injectors...
with a stock pump i thought more pressure mean less flow. anyone have a map of a stock EF fuel pump at different PSI?
Modified by civickid03 at 6:34 PM 12/19/2007
Old Dec 20, 2007 | 08:49 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: fuel pressure flow ratio (civickid03)
if you are already leaning out, then lowering fuel pressure will make it worse.. more pressure will give you more flow.
a fuel pressure regulator performs the same function as the **** on the garden hose. turning up the pressure increases the flow.
Old Dec 20, 2007 | 09:13 AM
92_civic's Avatar
Default Re: fuel pressure flow ratio (sanimalp)
turning up the pressure does not increase the flow...esp with a stock pump...think about your garden hose example...your restricting flow to increase the pressure...if it were me I would put a walbro in it and tune it with the vafc for stock fuel pressure settings...esp if your still running stock injectors
Old Dec 20, 2007 | 10:31 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: fuel pressure flow ratio (92_civic)
cracking a valve with 200psi of static pressure for half a second will release more material than cracking a valve with 100 psi of static pressure for half a second. the same theory applies to fuel injectors.
You will run into the upper limit of the fuel pump's flow if the pump cant maintain constant pressure, which might happen on the stock pump, as someone mentioned.
Old Dec 20, 2007 | 02:30 PM
civickid03's Avatar
who do i believe?
say the theory about the valve at 200 psi is true, wouldnt the pwm time also affect
pressure?
Old Dec 21, 2007 | 04:20 PM
spun Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_civic &raquo;</TD></TR><TR><TD CLASS="quote">turning up the pressure does not increase the flow...esp with a stock pump...think about your garden hose example...your restricting flow to increase the pressure
That is the dumbest thing I have ever heard. That has nothing to do with how fuel pressure works.
It all depends on how much the pump can flow but if the pump isn't being maxed more pressure = more fuel. If the pump is maxed out turning up the pressure wont really do anything.
I cant see how more fuel pressure can actually produce less fuel no matter what the circumstances are. The pump always flows the same.
Old Jan 2, 2008 | 03:03 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: fuel pressure flow ratio (spun Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">
exactly.
the time the injector is open at a given rpm and atmospheric pressure is the same if you dont change the fuel map which changes the injector pulse. The opening and closing of the injector would effect the static fuel pressure in a system where the pressure was being supplied by a pump that flowed at a similar rate to amount of fluid released from the system per increment of time. This is NOT the case on the fuel system in a stock honda, IE 240cc injectors and ~79 L/h stock fuel pump. whether or not you are running a stock fuel system remains to be seen, but in most cases, since the injected fuel volume is probably much lower than the flow rate (volume/time) of the fuel pump, the pressure drop would be negligible, and therefor not worth worrying about.
Old Jan 3, 2008 | 02:27 AM
SJersey's Avatar
3rd calculator down to show new pressure vs old pressure in flow rates:
http://kgparts.com/index.php?page=fuel-calc
tolowhb
Apr 6, 2004 06:42 PM
SOFLSOL
Feb 24, 2004 03:42 PM
SOFLSOL
Aug 20, 2003 02:38 PM
SOFLSOL
Aug 14, 2003 02:03 PM
01itr518
Jan 8, 2002 12:17 PM
