d15b swap into a 00 EJ8 acting wierd... need help
Old Dec 18, 2007 | 10:13 PM
h0ndah4bit's Avatar
Default d15b swap into a 00 EJ8 acting wierd... need help
OK my brother has a 2000 civic Ej8 with a d15b sohc vtec.
i'm pretty sure it's a swap into the civic but i'm not sure.
in the past week all of the following has happened.
Random misfires.
won't rev past 5,500 rpm (no Vtec)
car occasionally losing throttle response and doesn't regain it until the car drops under 3.5k RPM
he's using the stock 2000 civic ex ECU...
just recently started having a problem with it..
any ideas?
Old Dec 18, 2007 | 10:16 PM
NOFX's Avatar
H-T White Ops
Default Re: d15b swap into a 00 EJ8 acting wierd... need help (h0ndah4bit)
Yes, it's a swap. The stock engine is a D16Y8 1.6L SOHC VTEC.
Can't help you much more though.
Old Dec 18, 2007 | 10:31 PM
h0ndah4bit's Avatar
Default Re: d15b swap into a 00 EJ8 acting wierd... need help (NOFX)
yeah i knwo that's the motor but what do you think would cause these problems...
we tried swapping ecu's out with my 00 civic ex Ecu i think it's a P2T or P2P
and also tried using a OBD-1 P28 and it still acts retarded.
WTF is going On with this Civc?
Genaro781
Oct 30, 2015 09:39 AM
netty_speghetti
Jan 28, 2011 07:52 PM
SmOkIneLf
Jun 30, 2008 03:44 PM
d16Booger
Apr 11, 2006 02:58 PM
blaze08
Feb 25, 2004 09:39 PM
