b20vtec clearance..rs machine pistons
Old Dec 18, 2007 | 09:19 PM
lsvtec2000's Avatar
Default b20vtec clearance..rs machine pistons
i plan on running a b20vtec and i read a post that said if i run the rs machine type r replica for a b20..i can use any size cam without having any problems with valve to pistons contact..due to the pistons modified valve relief..b16 head by the way..can anyone give me any information about this..or point me in the right direction so i can get an answer...thanks
Old Dec 18, 2007 | 10:25 PM
quicksilver1689's Avatar
i ♥ snails
clay the head if your going to use "aggressive" cams in that b20. thats my stand on it
Old Dec 19, 2007 | 01:24 AM
LPoke's Avatar
yes sir... dyno prooben
Old Dec 19, 2007 | 07:45 PM
BILLY_BLING's Avatar
I ran a set of skunk2 pro 1 on these pistons no problem
Old Dec 19, 2007 | 07:59 PM
lsvtec2000's Avatar
Default Re: (BILLY_BLING)
thanks...do u know if i can run skunk2 stge2 cam on a stock b20b block
Old Dec 21, 2007 | 07:25 PM
LPoke's Avatar
i dont think its a good idea.. but i had tha stage 2s with my 84.5 rs
Old Dec 22, 2007 | 09:23 AM
atec's Avatar
Default Re: b20vtec clearance..rs machine pistons (lsvtec2000)
You should always clay the valve relieves, and meshure the clearences with vtec rocker locked....
whenever you assemble a engine with diffrent parts(other than stock)
Never assume that it will be okay. "Meashure"
Also remember to meashure valve to valve clearences.
Old Dec 22, 2007 | 06:12 PM
lsvtec2000's Avatar
Default Re: b20vtec clearance..rs machine pistons (atec)
well i have je 12.1 compression pistons..will i have a clearance issues with stage 2s with these
Old Dec 22, 2007 | 07:27 PM
the pro 1 are rated then just stage2! if you are willing have a machine shop mill the pockets back some
Old Dec 23, 2007 | 05:50 AM
atec's Avatar
Probably not, allmost all piston mfg oversize the valvepockets on their pistons.
BUT you should def meashure clearances.
If you have oversized valves make shure your clearences(Valve to valve) is within specs with these cams.
GSR_hatch936
Apr 13, 2010 01:14 PM
h22 kid
Oct 23, 2009 04:30 PM
imnike9000
Sep 23, 2009 09:03 AM
blackhatchb20
Jun 14, 2006 07:03 AM
