What turbo for 140mph traps?
Old Dec 18, 2007 | 08:13 PM
2LiterTurboSeR's Avatar
Default What turbo for 140mph traps?
If I was looking to propel, say a 92-95 Coupe to 140mph in a 1/4 mile, how much power would I need and what turbo would best suit the application?
Motor is a 2.0 GSR, 9:1 compression, CTR Cams, Edelbrock VictorX. Full weight EG Coupe with power everything.
I'm guessing 700whp or more, but what turbo? T4/T67? GT4088? recommendations?
Just a discussion among friends, a good friend is looking to take his car to the next level and I am trying to help him out. Thanks in advance
Old Dec 18, 2007 | 08:27 PM
SwappedTURBOegg's Avatar
and the coupe is probably 2700 with driver. maybe more.
Old Dec 18, 2007 | 09:31 PM
morgan@synapse motorsport's Avatar
Default Re: (SwappedTURBOegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">and the coupe is probably 2700 with driver. maybe more.
i dont think its that heavy, then again i never weighed my car.
i would say my car is comparable to the OP, i went 142mph with my 35r full interior 95 coupe with a cage. the 35r had a lot more room to go but i didnt have the fuel for it. im expecting to trap 138-140mph with my 3076r i have now in the same chassis. i think the 35r could push it into the 147-148mph. if you want 140mph in a full weight coupe i would go with a 35r.
the gt4088 and t67 would push that coupe into the 150+mph.
Old Dec 18, 2007 | 10:16 PM
nfn15037's Avatar
Default Re: (rota92)
I've had a customer with a 2400+ lb coupe running 136-137 (109 8th mile) with only !440 wheel HP. It wouldn't take much more to run 140 trap speeds, definitely doable on a 35R though!
Old Dec 18, 2007 | 10:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">
With who in it? lol
It's still going to haul the mail with a 35R on it no problem, and it will NOT need 700 whp. Thats the point I was trying to make.</TD></TR></TABLE>lol
Old Dec 18, 2007 | 10:55 PM
With who in it? lol
A 35R was actually the first thing that came into my mind when we started talking about doing everything, I think tapping 140 flat would be more than enough car for him, considering the car sees alot of street action also on it's current setup.
Thanks alot for the quick and helpful unput guys
Old Dec 19, 2007 | 01:14 AM
blinx9900's Avatar
Default Re: (2LiterTurboSeR)
92-95 ex coupe with all options is ~2800lbs! i weighed my friends the other day, it was heavier than a stock GSR we weighed the same day...
Old Dec 19, 2007 | 01:51 AM
mighty137's Avatar
What drivetrain???
Old Dec 19, 2007 | 02:21 AM
hellakapps's Avatar
Default Re: (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">92-95 ex coupe with all options is ~2800lbs! i weighed my friends the other day, it was heavier than a stock GSR we weighed the same day...</TD></TR></TABLE>
1995 Honda Civic EX CPE MT 2443
1998 acura gsr 2667
he must haul lead around in the coupe
Old Dec 19, 2007 | 06:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LiterTurboSeR &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks alot for the quick and helpful unput guys </TD></TR></TABLE>
what turbo is he using now?
Old Dec 19, 2007 | 07:24 AM
PSI2HI's Avatar
Former Vendor
Default Re: (mike@synapse motorsport)
I trapped 141 on a 57 trim @ 23 psi.
92 hatch 2300 lbs, made 451whp @ 21.5 psi.
Old Dec 19, 2007 | 09:37 AM
Default Re: (mighty137)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mighty137 &raquo;</TD></TR><TR><TD CLASS="quote">What drivetrain??? </TD></TR></TABLE>
Right now it's a LSD GSR Transmission
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">
what turbo is he using now?</TD></TR></TABLE>
Some cheap Ebay "T70" that we believe just bit the dust
Old Dec 19, 2007 | 09:40 AM
THEDirtyDseriesWOOT's Avatar
Default Re: (PSI2HI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSI2HI &raquo;</TD></TR><TR><TD CLASS="quote">I trapped 141 on a 57 trim @ 23 psi.
92 hatch 2300 lbs, made 451whp @ 21.5 psi.</TD></TR></TABLE>
did you sell that 57 trim to RC000E on this forum..
he said somthing about he got it from yall i just bought that turbo for my daily lol
Old Dec 19, 2007 | 09:50 AM
what is he trapping with that?
Old Dec 19, 2007 | 10:46 AM
crowder13's Avatar
i vote 67
Old Dec 19, 2007 | 02:42 PM
what is he trapping with that?</TD></TR></TABLE>
Not sure at the moment, all the tracks closed when we put it on. It went 116 on 15 psi with a .50 trim t3/t04e and switching to the bigger turbo made a huge difference on his top end.
Old Dec 19, 2007 | 02:46 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">On what dyno was this 440 made?</TD></TR></TABLE>
Dyno Dynamics using a T3/T67 or something, not 100% sure but it was a T3 exhaust housing.
Old Dec 19, 2007 | 03:17 PM
boostedcivicsir's Avatar
Mr. Badwrench
140mph t3t67ho down 5* timing up top, and crappy short time. (2550 with me in it)
we thinks there is a 148-150 in it also.
Old Dec 19, 2007 | 04:54 PM
kranked91dx's Avatar
Default Re: What turbo for 140mph traps? (2LiterTurboSeR)
no no no !, the GT 40 is way to large, you'll end up with a big lag...
gut the sh*t out of your interior, and add a GT35 to your setup,
anywhere between 580 and 620 Hp should get you at 140 over MPH to the line
with good tranny clutch slick combo.
small thought !
chow !
jp
Old Dec 23, 2007 | 03:38 AM
91jdmhatchback's Avatar
Default Re: What turbo for 140mph traps? (kranked91dx)
did everyone miss when nick posted that he was able to hit 141 with just a 57trim? oh and the car was in the 440-480 whp range.
Old Dec 23, 2007 | 07:37 AM
Newt Dog's Avatar
Default Re: What turbo for 140mph traps? (91jdmhatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">did everyone miss when nick posted that he was able to hit 141 with just a 57trim? oh and the car was in the 440-480 whp range.
It was more like 480hp to hit 141 mph. I went 136 mph with 461hp. This was with a sc6131e.
Old Dec 23, 2007 | 07:50 AM
Default Re: What turbo for 140mph traps? (Newt Dog)
i'm talking about nick at straght line specialties. and last time i saw it race it had a 57trim on it, and if a remember right it ran 10.57 at 141
Old Dec 23, 2007 | 12:32 PM
vtecspeed1320's Avatar
Shooting Star
my coupe was 2460 with a k swap in it and full interior. t3/to4e 57 trim, borgwarner 362, t3/67, t4/67, 35r. those are all turbos mentioned and that will get you in that 140mph trap speed. Just depends on how much you wanna spend.
Old Dec 23, 2007 | 12:43 PM
nitrousballa's Avatar
Default Re: (vtecspeed1320)
for a 140 traps...get one off a SEMI TRUCK .......LMAO
harv
jay2415
May 24, 2018 05:56 PM
wliwl
Apr 8, 2008 04:37 PM
tbagn
Honda Civic (2006 - 2015)
42
May 24, 2007 09:34 AM
RustyRex
Feb 5, 2006 09:49 PM
jbell
Jul 16, 2005 02:58 PM
