car dies when hitting brakes and idle surges up and down HELP!!!
Old Dec 18, 2007 | 07:08 PM
supertuner91ef's Avatar
Default car dies when hitting brakes and idle surges up and down HELP!!!
WORKING ON A 1990 HONDA ACCORD, IT DIES WHEN I PRESS THE BRAKES AND THE IDLE SURGES. WHAT COULD BE CAUSING THIS??? IF ANYONE CAN HELP OR GIVE ME AN IDEA I'D APPRECIATE IT.
Old Dec 18, 2007 | 07:25 PM
Default Re: car dies when hitting brakes and idle surges up and down HELP!!! (supertuner91ef)
PLEASE DOES ANYONE HAVE ANY IDEAS?
Old Dec 18, 2007 | 10:21 PM
radiuslight's Avatar
Ive had that problem before
once it was because my coolant level was low
then once again when my idle was set too high
start there check it out
Old Dec 20, 2007 | 01:10 PM
Default Re: car dies when hitting brakes and idle surges up and down HELP!!! (radiuslight)
tired that what else could i try
Old Dec 20, 2007 | 01:24 PM
two_brothers_racing's Avatar
there is something wrong with your brake booster when you hit the brakes the power that the booster takes is messing with the idle
Old Dec 20, 2007 | 05:40 PM
hondadude's Avatar
The brake booster uses a large amount of the available intake manifold vacum.
I'd start by looking around for broken vacum lines, or vacum leaks.
Also check the IACV, idle should drop a couple hundred RPM if you unplug it with the engine idling.
muddmonky
11
Jan 24, 2013 05:34 AM
wasabijim
Dec 27, 2010 03:00 PM
seeodywhy
Jul 19, 2009 11:30 AM
u_gnit
Aug 11, 2006 09:21 AM
StupidSlowRSX
Mar 17, 2004 04:38 PM
