ef plug wires on eg??
Old Dec 18, 2007 | 09:42 AM
dertymatt's Avatar
Default ef plug wires on eg??
i have a cyl not firing and instead of buying new wires i want to test it. my friend has a ef and i was wondering if i can use the wire off his car to test it on my car?
Old Dec 18, 2007 | 10:36 AM
1SiC 3DR's Avatar
Default Re: ef plug wires on eg?? (dertymatt)
if its a d15b something then yes any ef will work but if its a D16Z6 it will still work it will just look stupid ish
Old Dec 18, 2007 | 10:59 AM
dertymatt's Avatar
Default Re: ef plug wires on eg?? (1SiC 3DR)
yeah i dunno the code for the ef but my eg is d15b7
Old Dec 20, 2007 | 05:01 AM
1SiC 3DR's Avatar
they will work fine
Old Dec 20, 2007 | 06:09 AM
jordanhxc's Avatar
last time i checked ef wires didn't fit down the hole because they're too big
Old Dec 20, 2007 | 06:47 AM
1SiC 3DR's Avatar
Default Re: (jordanhxc)
the d15b7 found in 92-95 and the d15b1/2,d16a6 found in 88-91 actually use the same cast on the head and the same valve cover so i'm curious of why it wouldnt work and if you order honda wires for any of the above they all have the same part number 32722-P01-000
Old Dec 20, 2007 | 01:01 PM
dertymatt's Avatar
Default Re: (1SiC 3DR)
yeah they fit. but still didnt fix the problem. 99% sure there is water going into the cyl. im changing the headgasket this weekend.
Old Dec 20, 2007 | 03:24 PM
1SiC 3DR's Avatar
Default Re: (dertymatt)
i would get the head checked before hand, make sure its flat and doesnt have any cracks or serious warpage and also a leakdown test will tell if u do head gasket issues
Joericci46
May 12, 2018 06:34 PM
88EFsedan2
Feb 18, 2012 03:29 PM
88CReXin
Mar 15, 2011 03:28 PM
anejoh
Oct 14, 2003 12:47 PM
Steve90HB
22
Aug 21, 2003 12:55 AM
