Check Engine Light Blinking
Old Dec 18, 2007 | 06:27 AM
zicosonic's Avatar
Default Check Engine Light Blinking
I have a 2000 Honda Civic EX ... I was driving to work this morning and suddenly the check engine light started blinking.
Then when i stopped in the parking lot, the car started vibrating and lot and seemed like it was going to die on me. I switched it off. Now i tried starting it and it started just fine, but it is still vibrating.
Could someone help me. It is safe to drive the car. Any ideas.
In advance, your help is highly appreciated. Thanks.
Old Dec 18, 2007 | 06:36 AM
90efhatch's Avatar
Default Re: Check Engine Light Blinking (zicosonic)
You need to search the forum and find out how to check the codes on the ECU and then post the code. It sounds like it has a miss but need a code to make sure.
Old Dec 18, 2007 | 06:52 AM
97Ej6mike's Avatar
Blinking indicates a misfire, (dead sparkplug) .
No, its not a good thing. Its not good to run a motor without all 4 cylindars running correctly.
Old Dec 18, 2007 | 06:54 AM
zicosonic's Avatar
Default Re: Check Engine Light Blinking (90efhatch)
Thanks for the info.
I guess i will take it to Auto Zone and see if they can hook up the ECU and find the code out or else i will try to read the forum and find out how the read the code.
If anyone has any ideas please reply.
Thanks ...
Old Dec 18, 2007 | 06:55 AM
zicosonic's Avatar
Default Re: (97Ej6mike)
Dead Spark plug.
How would i find out which spark plug is dead. I guess i should just change all ..
Thanks.
Old Dec 18, 2007 | 08:00 AM
ifIexplode's Avatar
Id change your spark plug wires while your at it, Just use a marker to remember the firing order.
Old Dec 18, 2007 | 08:20 AM
old man neri's Avatar
It's not necessarily a spark plug that is the cause. I had it happen to me once and it was actually the injector wire that had sheared off.
All you need to read the code is a paper clip. There are several how-to's with pictures.
Old Dec 18, 2007 | 08:27 AM
zicosonic's Avatar
Default Re: (old man neri)
If its not too much trouble, could you please post a link to one of the threads for how to read a code .... I am a real noob at these things ...
Thanks
Old Dec 18, 2007 | 08:35 AM
mechanix619's Avatar
Default Re: (zicosonic)
This is on page one.
https://honda-tech.com/zerothread/1901557
Modified by mechanix619 at 9:46 AM 12/18/2007
67tj67
Oct 4, 2018 11:38 AM
rhdins
Jun 11, 2008 10:13 AM
NJcivic21
Dec 11, 2005 01:26 AM
jdmazm
Apr 21, 2005 07:58 PM
wadafa
11
Oct 3, 2002 03:49 PM
