Suspension & Brakes Theory, alignment, spring rates....
What kind of grease/anti seize for suspension bolts/metal bushings?
Old Dec 17, 2007 | 10:26 PM
civicdelsol33's Avatar
Default What kind of grease/anti seize for suspension bolts/metal bushings?
What type of grease should I use that isnt going to corrode anything? I have a 93 Del Sol with OEM bushings. What kind of anti seize do I use? ANd where can I buy it? I also hear not to use Moly because it will eat my OEM bushings?
Can anyone just point me in the right directions here to keep my suspensions bolts from ever rusting inside of the bushings again. I hate broke bolts.
Old Dec 18, 2007 | 11:57 AM
Default Re: What kind of grease/anti seize for suspension bolts/metal bushings? (civicdelsol33)
Bump
Old Dec 18, 2007 | 12:41 PM
artifex's Avatar
say it
As long as you don't coat the rubber part of the bushing with anti-seize, it should be fine. You don't need to use a lot.
Old Dec 18, 2007 | 03:23 PM
Dan GSR's Avatar
Default Re: (artifex)
i use permatex anit seize from autozone
Old Dec 18, 2007 | 06:57 PM
Targa250R's Avatar
be professional
I just use regular copper anti-seize compound from any parts store. You don't need to use too much of it. Just dab some on the bolt, smear it into threads and around the shank, and wipe off the excess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdelsol33 &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone just point me in the right directions here to keep my suspensions bolts from ever rusting inside of the bushings again. I hate broke bolts.</TD></TR></TABLE>
Anti-seize isn't necessarily going to guarantee you won't have problems, but it helps.
The best advice I can give you is to store your car during winter and never drive it on a salted road.
Old Dec 18, 2007 | 07:40 PM
Thanx guys that helps alot. SO do u think it would be ok to use moly based then?
Old Dec 18, 2007 | 07:58 PM
Targa250R's Avatar
be professional
Default Re: (civicdelsol33)
I would imagine you could use the molybdenum disulfide grease, but it makes a nasty mess and I don't personally use it for anything other than axles. I prefer anti-seize compound for thread lubricant and fastener rust/corrosion prevention.
Old Dec 19, 2007 | 06:45 PM
Dan GSR's Avatar
Default Re: (Targa250R)
grease is better than nothing
but if your concerned about seizing bolts in your suspension
there is a reason its called "anti-sieze"
Old Dec 19, 2007 | 09:28 PM
K I went ahead and bought some Permatex (sp?)from autozone today. It is aluminum based. Will this stuff be alright?
Old Dec 19, 2007 | 10:26 PM
Dan GSR's Avatar
that what i use
good stuff
andyz
Suspension & Brakes
23
Apr 10, 2012 12:11 PM
civicdelsol33
Dec 13, 2007 08:18 PM
quest4boost
10
Nov 29, 2006 05:56 PM
Shake and Bake
26
Jan 14, 2006 11:57 PM
Civicse
16
Dec 20, 2005 06:45 PM
