95 civic rear disc?
Searched and couldn't find the exact answer, Do I need new brake lines for the rear disc conversion? And Will e-brake cables from any rear disc civic/integra work or do I have to get the 95 civic w/abs cables? Thanks ejoner.
No, you do not need need new brake lines for the rear disc conversion.
For your civic any ebrake cable from 2/4 door integras will work, as well as 2/3 door ex/si civic cables.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">california residents seem to have difficulty finding the faq.</TD></TR></TABLE>
That's Nor Cal.
That's Nor Cal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
That's Nor Cal. </TD></TR></TABLE>
^^ Seriously... its because they are too busy getting "hella hiefey" or something.
Cool Cool Island Breezes. BOY-EE
You need the brake lines. You need the cables from either a DC2/4 or an "EG" with rear disk. Abs or not, doesn't matter.
i took rear discs off of an integra. and the ebrake cables all lined up perfectly and the brake lines worked.. GL ohh and i have a eg hatch
Lol sorry it was late and I guess I didn't search too well, Thanks for the info lol I just looked at what I bought and it did come with brake lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">You need the brake lines. You need the cables from either a DC2/4 or an "EG" with rear disk. Abs or not, doesn't matter.</TD></TR></TABLE>
Why won't the stock EG lines work? Mine work just fine on my rear disc setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">
Why won't the stock EG lines work? Mine work just fine on my rear disc setup?</TD></TR></TABLE>
They will. They have to be lines from a rear disc, though. The op asked:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Searched and couldn't find the exact answer, Do I need new brake lines for the rear disc conversion? And Will e-brake cables from any rear disc civic/integra work or do I have to get the 95 civic w/abs cables? Thanks ejoner.</TD></TR></TABLE>
They can't be the same lines as the drum setup. That's what I meant.
the rear brake lines from a civic with rear drums will not work on a rear disc conversion. the hoses from the drums are too short.
They will. They have to be lines from a rear disc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
Well I kept my stock brake lines from my drums on my EG and they have worked just fine on my rear discs.
</TD></TR></TABLE>Well I kept my stock brake lines from my drums on my EG and they have worked just fine on my rear discs.
Well I kept my stock brake lines from my drums on my EG and they have worked just fine on my rear discs.</TD></TR></TABLE>
That doesn't make sense. The fittings are totally different. I'm talking about the RUBBER lines that go to the caliper. Not the metal lines that travel under the car.
Philosofy, I dig your sig quote lol.
Oh, ok nvm.
Oh, ok nvm.
, i have 3 rear disc swaps, one eg and 2 ek's. with that being said, i was unable to use the rear brakes hose because the did and will not reach the caliper.
the worst thing you can do is rig up a brake job, i would hate to ride in your car knowing what i know now.
, i have 3 rear disc swaps, one eg and 2 ek's. with that being said, i was unable to use the rear brakes hose because the did and will not reach the caliper.the worst thing you can do is rig up a brake job, i would hate to ride in your car knowing what i know now.
the worst thing you can do is rig up a brake job, i would hate to ride in your car knowing what i know now. </TD></TR></TABLE>
I think he was talking about the metal hardlines that run underneath the car from the master cylinder.
, i have 3 rear disc swaps, one eg and 2 ek's. with that being said, i was unable to use the rear brakes hose because the did and will not reach the caliper.the worst thing you can do is rig up a brake job, i would hate to ride in your car knowing what i know now. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">
^^ Seriously... its because they are too busy getting "hella hiefey" or something. </TD></TR></TABLE>
aye its hyphy and yes we go dumb, :D YEe!!!
Darrell Woods
Oct 7, 2015 07:50 AM
dantamparacer
Suspension & Brakes
Feb 21, 2012 06:18 PM
Neutex22
Jan 17, 2005 10:32 AM
