Turbo Pistons.
Is it safe to run turbo pistons in a b18c1 , with out the turbo? i dont c a problem with it as long as u have a good tune, what does every one thinks . im just wondering because im still gettting parts for my turbo set up.
Assuming your "turbo" pistons are lower compression pistons from any of the reputable piston manufacturers, it should be fine to run them with a good tune. If they are really low compression, the car may be low on power, but it will still be safe to drive.
Craig
Craig
what are some pistons out there. im a N/a guy , lately ijdgaf and want to go fast for cheap. what better way than a turbo set up . i have a healthy stock slightly bored gsr , everyone saids i can just run that at 8 psi safely
ahc'monracing
Jun 18, 2003 02:05 PM
