FS: random b-series parts and garage clean up sale...
From: gravity rides everything...everything will fall, se GA/ne FL
*most pics have been taken, but still need to be uploaded etc*
-'95 gsr head. clean. excellent condition. comes with cams. no intake stuff (but i do have some of it), no distributor, and no water neck.
$450 plus s/h.
-jackson racing supercharger for gsr. excellent condition. clean. non boost raising pulleys (6-7 psi standard). everything else included to set up minus fuel accesories.
$ to be decided/ taking offers.
-'96 clean and uncut LS/b20 valve cover
SOLD
-'97 B20 not so clean valve cover. salvage yard writing and two wrinkle paint chips.
$38 shipped
-'90 uncut project LS valve cover with oil cap. good for refinish/polish/etc.
$25 shipped
-'95 gsr valve cover, uncut. couple random wrinkle paint chips.
$50 shipped
-shaved b-series vtec valve cover. refinish project. end cut. needs final prime/block/paint.
-$40 shipped
-semi polished b-series vtec valve cover. end cut.
$60 shipped
-NIB P2T (B16/ctr) OEM timing belt. brand new.
$55 shipped
-b16 intake manifold. not sure which gen/spec
$30 shipped
-cleaned and excellent condition PR3 b16 pistons w/ stock rods. good for compression jumps in your ls/vtec.
SOLD
-gsr idle air control (wide bolt spacing), perfect working condition
$40 shipped
-'00 si idle air control valve (closer bolt spacing), clean and perfect working
$40 shipped
-b-series tps sensors (3)
$25 shipped each
-throttle body map sensors (2)
$25 shipped each
-brand new oil pressure sender by autometer
$30 shipped
-used jackson/autometer boost sender
$30 shipped
-brand new G.E. 84mm B-series vtec headgasket
$60 shipped
-2.25mm steel lower compression steel gasket. dunno the - comp pts calculation.
$40 shipped
-brand new G.E. ls/vtec dowels (2)
$15 shipped
-polished greddy sandwich adapter. polished. double o-rings. 2 1/8th inch npt ports. 1 other port unsure of size. have all the plugs for unused ports
$45 shipped
-'95 obd1 gsr distributor. good working condition. comes with two caps (black oem and clear blue moroso cap)
$125 shipped
-'00 SI distributor, perfect working condition
$160 shipped
-'95 gsr alternator. perfect working condition.
$65 shipped.
-19mm Nuspeed rear sway. spherical bearing links, poly bushes, brand new D brackets, beaks and hardware. fits EG/DC
$145 shipped
-clean and real OEM jdm CTR front upper strut bar. no chips.
$90 plus s/h
-clean and real OEM jdm ITR upper front strut bar. clean.
$100 plus s/h
-CRX radiator, great condition, no leaks.
$65 plus shipping
-NX wet kit. 50 shot i think. should have everything to hook up and go.
$275 plus shipping and handling
-Momo competiton steering wheel. excellent condition with hub and horn button.
$175 shipped
-civic dual autometer gauge bezel, unpainted, no holes.
-$25 shipped
-'02 civic wheels/SI wheel style. ok condition. with good tread name brand tires and centercaps.
$400 plus s/h
-'95 gsr cams, intake and exhaust, great condition
-$60 plus s/h
-ITR valves (intake and exhaust). straight and clean as they get
-$75 bucks plus s/h
-(3) LS oil pans, clean and undented and untapped
$40 shipped each
-(3) LS blocks w/ bare/mains/wind trays/pick ups/rear seal plates. clean. legit (pics and numbers will be posted soon).
(2) need overbore or sleeves due to rust pits. $80 each plus s/h
(1)'96 is great shape @ 81mm $120 plus s/h
-excellent condition ground control coilovers with adjustable shocks (have to check brand). fits EG/DC lumps
$ to be announced
-black JDM EG hoptional console/ usdm cup replacement. good condition.
$75 plus s/h.
-usdm EG coupe/hatch headlights (2 sets). excellent condition.
$65 shipped each set
-'98 gsr front seats w/ rails. excellent condition.
$150 plush s/h
-'96? integra rear seats. great condition.
$60 plus s/h
-L & R usdm ITR door panels. great condition.
$ make offer/to be decided
-civic EG spoon copy side mirrors, painted all white (unsure if it's frost or whatnot)
SOLD
-DC spoon copy side mirrors, black base/shitty white paint job
SOLD
-jdm itr (zinc) shift linkage w/ skunk dual bend short throw shifter (i think)
$125 shipped for the linkage
$45 shipped for the shifter
-hydro b-series front trans mount, bracket, hardware. untorn/ripped mount rubber.
$65 shipped
-ITR transmission j4d. clean, legit, and great condition. no vin tag as this was purchased as a brand new unit from acura. inspected. replaced 3/4/5 brass blocking rings. deburred synchro sleeve mesh. and replaced 3, 4, 5 countershaft gears which had broken teeth. resealed with hondabond. will come with two brand new axle seals.
$1100 plus s/h. available now. optional gsr 4th and/or 5th or optional LS fifth set. free installation.
*lots of other things will be added soon kids. stay tuned.
*PM me with your interests. I expletiveING HATE FLAKERS and DREAMERS. no money no honey so save the time for you and me
Modified by not so civic at 10:22 PM 12/24/2007
$450 plus s/h.
SOLD
$38 shipped
$25 shipped
$50 shipped
-$40 shipped
$60 shipped
$55 shipped
$30 shipped
SOLD
$40 shipped
$40 shipped
$25 shipped each
$25 shipped each
$30 shipped
$30 shipped
$60 shipped
$40 shipped
$15 shipped
$45 shipped
$125 shipped
$160 shipped
$65 shipped.
$145 shipped
$90 plus s/h
$100 plus s/h
$65 plus shipping
$175 shipped
-$25 shipped
$400 plus s/h
-$60 plus s/h
.-$75 bucks plus s/h
$40 shipped each
$ to be announced
$75 plus s/h.
$150 plush s/h
$60 plus s/h
SOLD
SOLD
$65 shipped
they are cloth. dark grey with 'designer' pattern. they came out of a supersonic blue/purple on a '98 gsr.
i'm gonna be in orlando x-mas day for a couple days. i can bring parts and meet up etc!!! on the way from jacksonville or around orlando.
not so civic
Jan 29, 2008 06:08 PM
-bull expletive!!!
