Trunk light not working all the time
Old Dec 17, 2007 | 01:52 PM
shortlid's Avatar
Default Trunk light not working all the time
When I open the trunk on my '99 Honda Accord EX sedan some times the trunk light comes on some times not. I thought it was the bulb, but if I jiggle or hit the light it has no effect. Sometimes it comes on a minute after I first open the trunk? Then some times it works great, sometimes not? Where is the switch for this trunk light mounted??
Modified by shortlid at 3:51 PM 12/17/2007
Old Dec 19, 2007 | 01:04 PM
shortlid's Avatar
Default Re: Trunk light not working all the time (shortlid)
No one has had this issue? Is this the bulb or a switch, and where is said switch located.
Old Dec 19, 2007 | 05:12 PM
02 accord's Avatar
The switch is on the latch, which is located on the trunk lid.
Old Dec 19, 2007 | 05:30 PM
cb7tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortlid &raquo;</TD></TR><TR><TD CLASS="quote">When I open the trunk on my '99 Honda Accord EX sedan some times the trunk light comes on some times not. I thought it was the bulb, but if I jiggle or hit the light it has no effect. Sometimes it comes on a minute after I first open the trunk? Then some times it works great, sometimes not? Where is the switch for this trunk light mounted?? Modified by shortlid at 3:51 PM 12/17/2007</TD></TR></TABLE>
it could be the switch but i would make sure it was not the bulb. go ahead and put a new bulb in there. if the problem persist then go ahead and begin troubleshooting. I'm almost sure its just the bulb though
Old Dec 19, 2007 | 06:01 PM
shortlid's Avatar
Default Re: Trunk light not working all the time (02 accord)
Do I have to take the cover off the latch to get to the switch?
Old Dec 19, 2007 | 06:04 PM
02 accord's Avatar
Yah.
Old Feb 25, 2008 | 12:49 PM
shortlid's Avatar
Default Re: Trunk light not working all the time (cb7tuned)
Changed bulb in the trunk and still no light at ALL anymore. Not even intermitant as before, just does not work now.
Old Feb 25, 2008 | 05:35 PM
Chiovnidca's Avatar
Check the switch. It may be dirty or damaged.
Old Feb 26, 2008 | 10:02 AM
shortlid's Avatar
Default Re: Trunk light not working all the time (Chiovnidca)
Can I take it out of the latch mechinism without taking it all apart?
Old Feb 26, 2008 | 01:36 PM
Chiovnidca's Avatar
I dont think so.
Old Feb 17, 2015 | 05:11 AM
badlt's Avatar
Hello,
I also have this exact same problem. Bought a 2000 Accord EX about a month ago and the trunk light comes on sometimes, and sometimes not until a minute after the lid is opened. I tried wiring up LED's to it the other day and for 2 days the light would not work at all. Then today I opened to trunk to see if they were working and at first the LED's came on, then they went dim after a few seconds. I played with the wires to make sure they were secure and the LED's would flicker from bright to dim. I tried plugging in the original trunk light and that won't come on at all now.
No idea what is going on here...
Old Feb 18, 2015 | 05:31 PM
belairbrian's Avatar
You realize you bumped a 7 year old thread.
Anyway the light assembly appears to have a diode built in so adding another diode may complicate matters.
Pretty basic circuit. 12v to light assembly. Wire from light assy to switch on latch. Wire from switch to ground. When trunk opens latch assy switch closes and applies ground to light
Replace bulb, check to see if 12v is at lamp assy white with blue wire if so check ground (orange wire) through switch
Old Jun 15, 2015 | 11:31 AM
badlt's Avatar
Yep. I banged the trunk latch with my hand a couple times and the trunk light flickered. Took the latch apart and re-fastened the wiring. Trunk light works every time now. Thanks!
Old Nov 4, 2018 | 04:48 AM
Frostnova's Avatar
Also make sure there is no build-up on the contacts where it meets the lamp. Mine was driving me nuts and as I was going through with my meter trying to find the fail point must have scraped off whatever build up on the contacts that was causing the issue
Old Apr 30, 2019 | 11:44 AM
Hasan Khurshid's Avatar
I am having a similar issue. On the cluster when I open the trunk it shows the light without any problem but the trunk light does not comes on. The bulb I already have tested. Secondly I hook up the green wire from the turn signals and the one wire from the trunk light harness and the light starts to blink. So where is the problem and how can I access the complete wiring of the trunk light?
debsalot45
Dec 6, 2017 08:33 AM
lpdrumer
Feb 20, 2011 04:25 PM
aspire
Jun 19, 2009 05:19 AM
DragonBoy
Jan 31, 2005 02:12 PM
georgeda
Aug 12, 2003 03:53 PM
