UKDM B18C4 'P9K' ECU - Can i use Scan Gauge?
Old Dec 17, 2007 | 01:47 PM
MattyB801's Avatar
Default UKDM B18C4 'P9K' ECU - Can i use Scan Gauge?
Hi All,
I own a 1998 Honda Civic Aerodeck 1.8 VTi (B18C4). This was a European car, so you may not be too familier. Its a 1.8 16v DOHC Vtec (similar to DC2), but 169hp.
Anyway, it runs a 'P9K' ECU which is apparantly an OBDII unit. However, it doesnt feature a 16 pin OBDII socket, but the 2 plug OBDI style socket.
I very much like the look of Scan Gauge II, but it obviously requires an OBDII socket - does anyone know what i can do to run the Scan Gauge unit? (i'd rather not change the ECU if possible?)
cheers
Matt
Old Dec 17, 2007 | 02:08 PM
Jonathan_ED3's Avatar
You may have better luck asking on http://www.gassavers.org if you haven't already done so.
BlueIntegraBoy's Avatar
Default Re: UKDM B18C4 'P9K' ECU - Can i use Scan Gauge? (MattyB801)
This might work https://honda-tech.com/zerothread/1901557
Old Dec 17, 2007 | 02:32 PM
MattyB801's Avatar
Hi Jon - I have asked and searched on there too - but no response. Because the car in question is European spec and nothin similar was seen over in the States - they are of little help.
BlueIntegra - I'm not so sure what a link to reading fault codes will help me with? Maybe i'm being dumb and missing the point of your link?
thecca
Honda Civic (2001 - 2005)
Jun 19, 2013 05:34 PM
that-guy
Apr 8, 2011 09:04 AM
jlh911
Oct 26, 2005 07:21 PM
superduperman
Jul 23, 2003 06:35 PM
