Replacing Drivers engine mount...Washers needed?????
Old Dec 17, 2007 | 01:08 PM
stehigs321's Avatar
Default Replacing Drivers engine mount...Washers needed?????
Hey guys....I'm just in the process of replacing my drivers engine mount on my 96 civic coup with b18c1. I found whoever worked on the car last used 2 washers below the 17mm nuts on the posts that connect to the block....should i use these or should there be no washers???
BTW: I got prothane bushings for this side so it wont tear again...they fit very well and look like they will benefit
Old Dec 17, 2007 | 01:16 PM
chad's Avatar
Moderator
Default Re: Replacing Drivers engine mount...Washers needed????? (stehigs321)
use washers if you have them....
have done many swaps that don't have them
Old Dec 17, 2007 | 01:17 PM
stehigs321's Avatar
Default Re: Replacing Drivers engine mount...Washers needed????? (chad)
they seem like cheap washers, some are stretched more than others. They arent whole washers, they have a small gap. some gap bigger than others. still use them??? They had 2 on each bolt
Modified by stehigs321 at 10:27 PM 12/17/2007
Old Dec 17, 2007 | 01:25 PM
stehigs321's Avatar
cmon guys...trying to get this done before sun falls down
Old Dec 17, 2007 | 01:31 PM
stehigs321's Avatar
should i use the crappy washers????
Old Dec 17, 2007 | 01:47 PM
stehigs321's Avatar
cmon guys...i need to know stat...should i use the crappy washers that were on there...there were 2 on each post...perhaps i should use 1 on each???
Old Dec 17, 2007 | 02:41 PM
stehigs321's Avatar
ok...so i used one 1 washer on each of the 3 bold that hold the "bracket" down to the mount and engine block. should i have done this?? or only washers on the studs that connect to the block...i got 1 input and used what he said...any other recommendations???
87sivtec
Apr 24, 2010 06:45 AM
De_tour
Feb 1, 2006 02:18 AM
idriveadelsol7
Apr 16, 2005 01:16 PM
Bbasso
Dec 10, 2002 01:13 PM
