Easiest way to remove PCV
Old Dec 17, 2007 | 12:54 PM
-me's Avatar
-me
Default Easiest way to remove PCV. 1996-2000 civic
1996 - 2000 Civic (except SI). Next time your going to change your oil, get underneath the car and remove the oil filter. Then there is a vacuum attachment directly above where the filter attaches (has a bell shaped cover) and it pulls straight out. Now if you look up you can see the PCV clear as day, with by far the most access to it.
Good luck and if I were you I would change it much sooner than later. If you do it this way you can change the PCV and your oil in 10 minutes without a sweat, but the longer you wait the harder the PCV will be to get out.
Modified by -me at 3:03 PM 12/17/2007
Modified by -me at 3:11 PM 12/17/2007
Old Dec 17, 2007 | 12:59 PM
zerovandez's Avatar
Cool.
Old Dec 17, 2007 | 01:08 PM
philosofy1's Avatar
Default Re: Easiest way to remove PCV (-me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -me &raquo;</TD></TR><TR><TD CLASS="quote">Next time your going to change your oil, get underneath the car and remove the oil filter. Then there is a vacuum attachment directly above where the filter attaches (has a bell shaped cover) and it pulls straight out. Now if you look up you can see the PCV clear as day, with by far the most access to it.
huh, what?! on what motor? and how can you see it when from under the car when it sits on top of the intake manifold?
i get what you are trying to do, but you should research alittle more and be more explainatory. it's alot easier to pull it from the top, from my experience. just my $0.02 though!
Old Dec 17, 2007 | 02:01 PM
-me's Avatar
-me
Default Re: Easiest way to remove PCV (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
i get what you are trying to do, but you should research alittle more and be more explainatory. it's alot easier to pull it from the top, from my experience. just my $0.02 though! </TD></TR></TABLE>
You're right I forgot to mention it's for the D series engines on 96-00 civic. On the 96-00 it sits under the intake manifold. Obviously you don't have a 96-00 D series civic, any one who has knows it's hard to even find.
Old Dec 21, 2007 | 08:39 AM
-me's Avatar
-me
bump.... just because when I searched so many people had recommended pulling of the throttle body.
mjayvee
Honda Civic (2006 - 2015)
38
May 2, 2007 06:33 PM
JDM_EK4_Coupe
Nov 3, 2006 03:28 PM
vtech_tuner
Aug 3, 2005 06:27 PM
Nishant
Mar 21, 2004 10:34 PM
nd8ch
16
Apr 22, 2003 12:53 AM
