quick question on integra LS alternators.. can i use a '94 alternator on a '00 motor?
Old Dec 17, 2007 | 12:24 PM
Neptronix's Avatar
Default quick question on integra LS alternators.. can i use a '94 alternator on a '00 motor?
Yeah, so i need an alternator for a swap in my '99 civic ex..
friend has a '94 integra alternator off an LS.. will it work on my '00 motor??
Old Dec 17, 2007 | 12:49 PM
philosofy1's Avatar
Default Re: quick question on integra LS alternators.. can i use a '94 alternator on a '00 motor? (Neptronix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptronix &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, so i need an alternator for a swap in my '99 civic ex..
friend has a '94 integra alternator off an LS.. will it work on my '00 motor??</TD></TR></TABLE>
if the laternator is off of a 94 LS and you have a 00 LS, then no.
it will mount with no problems, but due to the 94 being a obd1 motor, it has a different plug than the 00 (obd2) one.
Old Dec 17, 2007 | 12:55 PM
Neptronix's Avatar
hmm ok.. so just different plug.
i take it that it would not be very hard to jerry rig the right plug.. what is it.. two.. three prongs?
I could probably find the correct plug and cut it off a junkyard integra.
would that work?
Old Dec 17, 2007 | 12:59 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The plug is pretty easy. Get the male side plug from a OBD1 car. I dont remember the wiring exchange wire per wire. It's been a while.
The alternator bolts up, and then you just solder on the plug from an OBD1 car. Any civic/integra plug should work. done and done. That's how I had it on my 99 hatch with a 94 B16A swap.
Old Dec 17, 2007 | 01:00 PM
Neptronix's Avatar
cool. i'll go do that
Old Dec 17, 2007 | 01:04 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptronix &raquo;</TD></TR><TR><TD CLASS="quote">cool. i'll go do that </TD></TR></TABLE>
B serious is entirely correct! (running joke i guess).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptronix &raquo;</TD></TR><TR><TD CLASS="quote">hmm ok.. so just different plug.
would that work?</TD></TR></TABLE>
yes you can swap out the wires, but i have to take into consideration that i don't know you nor your mechanical skills.
Old Dec 17, 2007 | 01:20 PM
Neptronix's Avatar
I know my electrical.
If it's only ~3 wires.. no rocket science is involved.. just a multimeter and a guy who isn't color blind.. ha ha
Old Dec 17, 2007 | 01:25 PM
B serious's Avatar
You can search for the wiring exchange. Or get a wiring diagram for both an OBD2 and OBD1 car. Then go from there. The wiring exchange is obivously easier.
Old Dec 17, 2007 | 01:34 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Even easier IMO is to take the two alternators apart and swap out trhe voltage regulators, which also happen to be the very item that the engine harness plugs into!
I did this on my wife's old 1992 Si Hb with B16A2 swap - swapped the SOHC OBD1 voltage regulator into the OBD2 B16A2 alternator and it works to this day some 6 years later!!!
Old Dec 17, 2007 | 03:24 PM
Neptronix's Avatar
oh really?
but will my d series alternator bolt up to the b18b motor?
topshotta
Mar 13, 2010 12:09 PM
hmtcrxsir
Jan 7, 2010 10:59 AM
Neptronix
Dec 17, 2007 02:26 PM
boostedwagon
Nov 16, 2007 09:01 PM
Flexmyrex
Sep 9, 2002 01:38 PM
