Oil pumps
Old Dec 17, 2007 | 12:15 PM
chris.deyoung's Avatar
Default Oil pumps
Is it just me, or is there not alot of information about high performance oil pumps out there?
What are the top "tried and tested" brands? What should I avoid?, etc.
(for GSR B18C)
Old Dec 17, 2007 | 02:23 PM
Perfectionist's Avatar
Default Re: Oil pumps (chris.deyoung)
The purpose of an oil pump, obviously, is to provide lubrication to the various parts of the engine. The OEM pump is adequate to do the job.
If you are looking to replace a faulty pump. I'd suggest OEM. If you are looking to "upgrade" to a "high performance" pump. I'd ask why? More pressure could cause problems, not prevent them.
Maybe I'm all oil soaked here, so if I'm way off base, I welcome verifiable evidence to that effect.
Old Dec 17, 2007 | 06:32 PM
Default Re: Oil pumps (Perfectionist)
Well I figure that since I'm boosting this motor, a higher flowing oil pump would be beneficial since the oil feed for the bearings is supplied by the engine.
Also, I heard that the OEM cast steel gears can shatter at high RPM's.
Modified by chris.deyoung at 2:42 PM 12/18/2007
Old Dec 18, 2007 | 09:42 AM
slomofo's Avatar
GDD Member
My oil pressure gauge read the same on my stock pump at 8000RPM as my Spoon pump did, so i'm not really sure if aftermarket pumps are really worth it.
Old Dec 18, 2007 | 01:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris.deyoung &raquo;</TD></TR><TR><TD CLASS="quote">Well I figure that since I'm boosting this motor, a higher flowing oil pump would be beneficial since the oil feed for the bearings is supplied by the engine.
Modified by chris.deyoung at 2:22 AM 12/18/2007</TD></TR></TABLE>
Haven't heard about the OEM cast gear thing, so I can't comment.
However, a higher flowing pump without somewhere for the higher flow to exit would increase pressure to the point where oil would chose to exit throught the crank seals, etc.
AllShowNoGo727
Apr 25, 2014 05:00 PM
GI8U2racing
14
Nov 12, 2007 09:04 AM
2uy
Oct 23, 2005 09:56 AM
