turbo built jdm gsr, Turbo kit, Hondata s300, stock 98+gsr exhaust
Old Dec 16, 2007 | 11:36 PM
slowcar's Avatar
Default turbo built jdm gsr, Turbo kit, Hondata s300, stock 98+gsr exhaust
-2001 jdm gsr block-
-je pistons-
-eagle rods-
-arp headstuds-
-b16 head-
-skunk2 valve springs/retainers-
-adj cam gears-
-Itr intake manifold-
-clutchmasters flywheel-
-clutchmasters clutch-
-dc sports fuel rail-
Im sure theres more but you get the idea, motor has around 4k miles Never boosted past 5psi, and on a very rich tune.
-Turbo Kit-
-topmount manifold-
-t3/t4 turbo(57 trim)-
-2-1/2 dp-
-38mm wg w/ 2 springs(5.psi 10. psi)-
-apexi bov-
-precision 450cc injectors-
-12x30x2.5 fmic-
-all charge pipes-
-hondata s300(w disk and cable)-
-stock 98+ gsr 2dr exhaust no cat! (will work for 94+ also)----$75 picked up
manifold was made by a local fabricator, it's very heavy duty. Turbo is a ebay special But was broke in properly and always had the proper restricter installed.
charge pipes arent the cleaniest but work fine.
I would like to sell everything together. $3500 I may part motor/turbo kit/ecu if there is enough interest.
Old Dec 18, 2007 | 01:05 AM
91redteg's Avatar
Default Re: turbo built jdm gsr, Turbo kit, Hondata s300, stock 98+gsr exhaust (slowcar)
if u feel like sellin the turbo i really need onelemme kno what u wouldask for it
jne
Jan 31, 2010 06:04 PM
fl_hmong_racer
Oct 7, 2004 12:52 PM
ITR9788
May 30, 2003 05:20 PM
turbod16y8
Apr 19, 2003 01:18 PM
