Suspension & Brakes Theory, alignment, spring rates....
which bolts should i worry about breaking
Old Dec 16, 2007 | 10:47 PM
povs9's Avatar
Default which bolts should i worry about breaking
95 del sol
wanting to remove all the suspension parts and replace the bushings, front and rear.
the bolt holding my rear lca to the strut broke and all of the other bolts on the rear were frozen- lca to frame, lca to sway bear, and lca to trailing arm. i didnt use much force because i was afraid to break more bolts. so my question, will all of the other bolts break just as easy as the real lca/strut bolt? i used pb blaster on all the bolts
Old Dec 17, 2007 | 03:52 AM
B16B_coupe's Avatar
HRD PKR
Default Re: which bolts should i worry about breaking (povs9)
mostly just some of the rears brake.. i really never saw a case where the front bolts break..
so i would say really only the rears
HotCheetos
10
Dec 11, 2010 09:07 PM
98Luder
Suspension & Brakes
Nov 13, 2009 08:24 PM
oMek
May 6, 2004 01:06 PM
Soda Popinski
Mar 30, 2004 05:18 PM
wideb18hatch
Mar 11, 2003 04:03 PM
