question on hooking up vtec
have a 97 coupe obd2 non vtec harness and i have a obd2 to obd1 jumper any one no wat i have to hook up so vtec kicks in? wat plug wat pin i know it needs oil pressure signal and then the vtec cable just wondering which they are or if theres actually more to connect thanks
Im not sure about how a jumper harness works, so.. Heres is 92-95 Pin outs link,
http://www.phearable.net/tech/...5.jpg
And here is 96-98 PBDII pinouts.
And all the plugs for VTEC pressure switch, VTEC solenoid, And Knock sensor are Comman connectors, The knock sensor and Pressure switch Plug are the same.
Modified by ifIexplode at 2:40 PM 12/16/2007
whic cables are really necessary being the fact that my car is hybrid to the max and i dont even know wat harness is in there all i know is that its a obd2 dvtec and i have a jumper on it
Im not too sure, but on my h22, I needed the knock sensor, vtec solenoid, pressure switch, temp sensor, vss, yada yada.
I ended up going with a chipped p30, and I dont use the knock and temp
I searched vtec pressure and it said bypass it with the vtec solenoid wire and that should make me pop vtec .. true? or false
quicksol95
Mar 19, 2004 01:50 PM
