CAR KEEPS OVER HEATING
Old Dec 16, 2007 | 11:17 AM
93eh2hatch's Avatar
Default CAR KEEPS OVER HEATING
my car keeps over heating for basically no reason. i let all the air out of my coolant lines and put new coolant in. my thermostat isn't bad either... is there anything else that would make my car over heat?
Old Dec 16, 2007 | 11:24 AM
boostedNOTHARDLY's Avatar
change the headgasket recently? take the head off?
Old Dec 16, 2007 | 11:30 AM
1_white_eg's Avatar
Default Re: CAR KEEPS OVER HEATING (93eh2hatch)
possible blown head gasket, check timing, check radiator for corrosion.. hope that helps you...
93eh2hatch's Avatar
nope, havn't touched that. all i've touched recently is the intake manifold...
Old Dec 16, 2007 | 11:32 AM
93eh2hatch's Avatar
no radiator corrosion cuz i have a brand new radiator. head gasket being blown? how can i tell if its blown? and my timings fine
Old Dec 16, 2007 | 12:45 PM
gt35r's Avatar
Default Re: (93eh2hatch)
does your car drive normal? my first thought would be headgasket. when it drive does it have sweet smell out of the tailpipe?...
if you touched the intakemanifold...there is a waterpipe that goes to the intakemanifold and if you messed with that it may leak or the seal in the inatkemanifold gasket might be bad. sooo i would check that. it doesnt leak from anywhere?
Old Dec 16, 2007 | 01:55 PM
ke98248's Avatar
Default Re: (gt35r)
Make sure your fan is on when it's hot. If not, i can show you how to hard-wire it on all the time.
Old Dec 16, 2007 | 01:58 PM
homemadeturbo's Avatar
Well if there's no reason, then it can't be overheating. Just keep driving it.
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eh2hatch &raquo;</TD></TR><TR><TD CLASS="quote">my car keeps over heating for basically no reason. i let all the air out of my coolant lines and put new coolant in. my thermostat isn't bad either... is there anything else that would make my car over heat? </TD></TR></TABLE>
Describe this "basically no reason" for us, if you would. See, when a noob like yourself posts a problem and gives absolutely zero description of the symptoms of or circumstances leading up to said problem, it's basically impossible for us to do anything but ramble off lists of parts.
Why don't you tell us something like, I dunno, what kind of car you drive, maybe? You can add to that the trim level, the engine, any mods you've done within thirty days of the problem starting, etc. Does the overheating happen when you're moving or still? Is it rapid or slow? Can you control it by turning the heat on or not? Help us help you.
Old Dec 16, 2007 | 02:29 PM
Colby71's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eh2hatch &raquo;</TD></TR><TR><TD CLASS="quote">no radiator corrosion cuz i have a brand new radiator. head gasket being blown? how can i tell if its blown? and my timings fine</TD></TR></TABLE>
Compression test, check your coolant to see if it looks like oil got in there, and it smoke alot and burn oil.
Old Dec 16, 2007 | 02:41 PM
JustHere4ADay's Avatar
WHEEL Slayer
Default Re: (Colby71)
could also be the water pump
Old Dec 16, 2007 | 04:43 PM
blwn95civic's Avatar
Default Re: (homemadeturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homemadeturbo &raquo;</TD></TR><TR><TD CLASS="quote">Well if there's no reason, then it can't be overheating. Just keep driving it.</TD></TR></TABLE>
there has to be a reason or else it wouldnt overheat
to the op, give us a lil more info and if you messed with the intake mani like posted above there is a water line on it, that could be your issue but still we need more info
Old Dec 16, 2007 | 11:16 PM
93eh2hatch's Avatar
it did it tonight. i just put on a new skunk2 intake manifold. it drives fine. more power than normal haha, but i know the intake manifold was installed right, a certified mechanic helped me and a friend (who put his skunk2 intake mani on himself) install it. i know my head gasket is a little bad cuz it leaks a little.
it'll run normal temp during the day after i let out air out of the coolant hoses then torward the night when i'm on my way home, it starts to over heat. it actually random when it does it.
no oils getting into the coolant. and there are no leaks.
Old Dec 17, 2007 | 12:04 AM
alacard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eh2hatch &raquo;</TD></TR><TR><TD CLASS="quote">i know my head gasket is a little bad cuz it leaks a little.</TD></TR></TABLE>
I think you just answered your question.
Old Dec 17, 2007 | 12:17 AM
speedooo's Avatar
Default Re: (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">
I think you just answered your question.</TD></TR></TABLE>
i dont think he knows what he said
Old Dec 17, 2007 | 05:30 AM
Unceasing Measure
Default Re: (speedooo)
If you know your head gasket is bad, replace your head gasket. You should have done it before replacing your intake manifold
Old Dec 17, 2007 | 09:04 AM
krederlokes's Avatar
ok im in the same position also
My car is a 95 Civic
and radiator works fine, keeps overheating
water is being replaced every other day
car shakes badly when the car is still, like its ready to give out
possible blown head gasket?
or maybe time to throw in a new engine in their?
Old Dec 17, 2007 | 12:08 PM
93eh2hatch's Avatar
if my head gasket was bad would i have water in my oil?
and my head gasket has always been a little leaky, so it nothing new...
Old Dec 17, 2007 | 12:13 PM
Targa250R's Avatar
be professional
Default Re: CAR KEEPS OVER HEATING (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you tell us something like, I dunno, what kind of car you drive, maybe?</TD></TR></TABLE>
What a novel concept. Apparently you and I are the only ones who subscribe to this new school of thought
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eh2hatch &raquo;</TD></TR><TR><TD CLASS="quote">if my head gasket was bad would i have water in my oil?</TD></TR></TABLE>
No, not necessarily.
Old Dec 17, 2007 | 01:34 PM
archuletac's Avatar
Default Re: CAR KEEPS OVER HEATING (Targa250R)
okay....if your headgasket has always been a lil leaky than it probably finally went bad.
Old Dec 18, 2007 | 10:35 AM
93eh2hatch's Avatar
ok. well looks like all of you guys were right. i am almost positive its my head gasket.
went through everything and found that my head gasket is letting exhuast get into my coolant lines creating bubbles that make the car over heat. the tear or blow out in the head gaskets right around the 2nd cylinder i think thats what the compression test said anyways...
anyone know a cheap place for head gaskets? or a gasket set in general?
how are the ebay ones? are gaskets gaskets for the most part? (i only have a semi stock engine)
Old Dec 18, 2007 | 06:35 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eh2hatch &raquo;</TD></TR><TR><TD CLASS="quote">ok. well looks like all of you guys were right. i am almost positive its my head gasket.
how are the ebay ones? are gaskets gaskets for the most part? (i only have a semi stock engine)</TD></TR></TABLE>
I'm going to assume you have a '92-95 Civic with a D15B7 engine, because the B7 is notorious for head gasket issues. If you would have told us so in the first place, I could have saved you some aggrivation.
Do not buy cheap anything. Honda released a Technical Service Bulletin years ago about head gasket issues on the '88-95 non-VTEC D-series engines. They specify an updated head gasket (part number 12251-P01-004; you'll need 1) and new head bolts (part number 90005-PM3-004; you'll need 10) to address the problem.
I would highly suggest you buy those specific parts if you intend to change the head gasket (which I don't particularly recommend, but you can do as you wish). They are going to cost you around $177.10 + tax at any Honda dealership parts department. You must install and torque them as per the TSB: http://dmcknight.net/forumpics/97-047TSB.jpg (thanks to fireant for hosting). Don't forget to have the head checked for warpage.
Old Dec 18, 2007 | 07:35 PM
bpkmrtoes's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
I would highly suggest you buy those specific parts if you intend to change the head gasket (which I don't particularly recommend, but you can do as you wish). They are going to cost you around $177.10 + tax at any Honda dealership parts department. You must install and torque them as per the TSB: http://dmcknight.net/forumpics/97-047TSB.jpg (thanks to fireant for hosting). Don't forget to have the head checked for warpage.</TD></TR></TABLE>
DAMMIT!! no wonder i went through so many DX's. i'm was on my third one till i decided it was time for an upgrade.
Old Dec 18, 2007 | 08:33 PM
93eh2hatch's Avatar
well, i'm sorry but i have a far better engine (in my opinion) than a d15b7.
not on for sohc engines.
Old Dec 18, 2007 | 08:43 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eh2hatch &raquo;</TD></TR><TR><TD CLASS="quote">well, i'm sorry but i have a far better engine (in my opinion) than a d15b7.
If you told us what that engine was, it would help immensely
