ctr pistons?
Old Dec 16, 2007 | 09:53 AM
knuckk's Avatar
Default ctr pistons?
i have a ls/vtec setup and im deciding if i should put ctr pistons in my ls block i also have a gsr head with type r cams but im thinking about ctr pistons and cams what do you guys think my hp would be at and my compression should be?
Old Dec 16, 2007 | 11:04 AM
skoodles2k6's Avatar
Default Re: ctr pistons? (knuckk)
http://web.archive.org/web/200....html
if its the pct pistons your showing a 14.3:1 compression and yea thats way past limits on pump gas and id say stock sleeves plus most ppl say anything over 12.5:1 is pushing limits of 93 octane pluss i dunno if your going to have piston to valve clearance problems the pitch of the pct pistons are pretty stout.
Old Dec 16, 2007 | 09:20 PM
Seminole's Avatar
just go ITR, bit lower compression but still good. I'm using CTR in my engine BUT I'm also running Toda C2 Cams, and basically a ton of Toda mods. ITR is safer for street use probably on pump gas. I use 93 oct. and I run on CTR.
Old Dec 17, 2007 | 12:02 AM
fasterthanueg's Avatar
my friend runs ctr's in his ls-v gsr head man that thing is a pig hope you have deep pockets for race gas
Old Dec 19, 2007 | 06:07 AM
knuckk's Avatar
Default Re: (fasterthanueg)
lol wordd i think im just gunna go itr pistons.
j spec
11
Jul 26, 2006 01:36 PM
MRCHUNDOESAY
Dec 2, 2005 09:52 PM
AllTDMnotJDM
12
Nov 13, 2002 09:52 PM
DarkSubRosa
Feb 28, 2002 03:57 PM
stretracr
Jun 26, 2001 06:16 PM
