fuse info
Old Dec 15, 2007 | 11:38 PM
radu's Avatar
Default fuse info
im looking for information regarding fuses
my 98 accord ex v6 keeps blowing the same fuse
i have no installed any stereo or messed with the electrical in any way... yet it is starting to constantly blow a few times/week
it is a 20amp fuse labelled 'stop lamp'
its the fuse that controls the horn/brake lites
consequently, when it blows... my car is stuck in park and without a shift-lock release button.. this is quite a pain in the a!
my question is... where should i start looking to solve this problem?
Old Dec 16, 2007 | 01:28 AM
SuShiBoiiii's Avatar
Default Re: fuse info (radu)
for the time being you might step it up on the amp like a 30 or 35...but defiantly some loose grounding or faulty wiring is going on
Old Dec 16, 2007 | 08:11 AM
radu's Avatar
Default Re: fuse info (SuShiBoiiii)
that wont cause a fire... or mess up the electrical further?
Old Dec 16, 2007 | 02:50 PM
next_evolution's Avatar
never put in a higher rated fuse unless your a tech and your looking for a short at the exact moment, as far as the blown fuse problem id check your brake lights for a blown bulb thats shorting to ground, this can happen and will cause a blown fuse which is a safety feature to keep from melting your electrical system, hence don't put in a higher rated fuse, unless your really cold and in dire need of marshmallows
Old Dec 20, 2007 | 11:00 AM
radu's Avatar
brought the car to honda.
i was told the horn needs to be replaced (30 dollar horn) .. labour about 1.5 hours. so 250.00CDN
regardless if i used the horn or not, a short in the circuit will cause the fuse to repeatedly blow. the brake lamp/horn are the same fuse.
jes thought id pass on the info for the next guy.
Old Dec 20, 2007 | 11:09 AM
Perfectionist's Avatar
Default Re: (radu)
Thanks for the update.
Mishima
Jun 30, 2009 09:08 PM
95_GTi_VR666
Nov 22, 2008 11:36 AM
MSchu
Oct 27, 2008 09:55 AM
Sic_DA_Nine
Jan 8, 2007 09:54 AM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
