Good 6.5" Component set or 2 ways. That have some moderate lows
Old Dec 15, 2007 | 09:39 PM
JDMCRX's Avatar
Default Good 6.5" Component set or 2 ways. That have some moderate lows
Im looking for a good set of 6.5" for my truck. I have some clarions in there and they have no bass at all realy i think the factories had more.
What do you guys use around 100ish or 150 at the most.
I listen to alot of hip hop and raggee and some alternative
Old Dec 16, 2007 | 07:17 AM
B18C_EJ8's Avatar
What are you powering them with?
Old Dec 16, 2007 | 11:58 AM
fcm's Avatar
fcm
Old Fart
Default Re: Good 6.5" Component set or 2 ways. That have some moderate lows (JDMCRX)
http://www.eclipse-web.com/point/sp6500.html installed properly and with about 2x75W RMS going to them, you should be impressed. 94
Old Dec 16, 2007 | 09:17 PM
JDMCRX's Avatar
Default Re: Good 6.5" Component set or 2 ways. That have some moderate lows (fcm)
I got a rockford 50x4 i was looking at the orion HCCA 6.5
Old Dec 20, 2007 | 06:14 AM
hb420's Avatar
Did you use dynamat?
Old Apr 17, 2008 | 12:37 PM
thekid03's Avatar
I've got a few questions along these same lines. '98 Nissan Frontier extended cab. Went up to Crutchfield and looks like front speaks are 6 3/4". I've got some equipment from old installs and I'll be driving fronts with an Xtant 4.4 that'll put out 2x200 bridged to 4ohms
System goals
1. Good sound quality but more focus on SPL than SQ. I've got a SQ-focused system in my car......Dynaudio 340's powered by an Arc XXK 4150. I'm not expecting that level of sound quality but it'd of course be great to get as close as possible
2. Good height to front-stage. I noticed there's a factory location high in each door for a tweeter. BUT, I'm gonna need a tweeter that either has solid off-axis performance or has solid on-axis performance but can swivel.
3. $350 budget max for a component set
4. Use factory mounting locations. This will be my first complete install of a stereo. Although I built a pair of home speakers in my teens and just finished re-doing the hatch portion of my other stereo I think I need to keep this as simple as possible.
The hatch took me about 5 times as long as it'd have taken anyone else.
5. Woofer of the component set needs to be mounted on a solid baffle. Maybe 1/2" MDF.
6. I'm really not a fan of hard-dome tweeters. I've yet to hear a pair I've really liked.
====> So, based on this my main question would be the off-axis performance of the Eclipse tweets in the set mentioned in the below post....I noticed they are removable so I could install them in the factory location. I'm of course up for component sets less than $350 if I can get meet or come close to meeting the goals for my front-stage.
I was also looking at the Polk DB 6750's.
Does anyone have experience with JL's component sets? If so, what's your impression of sound?
Miscellaneous:
I'll be taking my other Xtant amp....an x1001 and running this mono to a single 12w7 or 13w7.
Fitting all of this is another story but I've got a couple ideas in mind....I'm gonna get some cardboard and create models of both amps, sub enclosure and my 1/3 octave EQ and play around with a few things and see what works out best.
Amp power & speaker RMS......I'm personally of the opinion it really doesn't matter if there's a mismatch.....what you do with the volume control and gain settings is what counts. The reason I say this is because I notice many of these 6 3/4" speaks in the $350 range aren't rated at 200 watts RMS or I suppose this actually is true of many 6.<x>" speaks.
And of course if you guys have any tips/tricks/advice/etc I'm all ears......
Modified by thekid03 at 1:44 PM 4/17/2008
Old Apr 17, 2008 | 09:12 PM
geerexx's Avatar
Default Re: Good 6.5" Component set or 2 ways. That have some moderate lows (thekid03)
if your looking for a set of good budget components sub $100 range check out TMA audio which is a sub company of JL audio. millionbuy.com carries them and they ship fast. $75 for the components and about $50 for 2 ways.
Old Apr 20, 2008 | 11:40 AM
junkspeedproject's Avatar
Default Re: Good 6.5" Component set or 2 ways. That have some moderate lows (geerexx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geerexx &raquo;</TD></TR><TR><TD CLASS="quote">if your looking for a set of good budget components sub $100 range check out TMA audio which is a sub company of JL audio. millionbuy.com carries them and they ship fast. $75 for the components and about $50 for 2 ways.
ill be ordering those components this week. ill let you know how it turns out.
sup geerexx
Old Apr 20, 2008 | 11:42 AM
geerexx's Avatar
Default Re: Good 6.5" Component set or 2 ways. That have some moderate lows (junkspeedproject)
greetings rgboooooy, components all around FTW! hahaha... minus well right? 150 for the set doooh
Old Apr 20, 2008 | 11:53 AM
LOL. "minus well right" hahahaha
Old Apr 23, 2008 | 01:55 AM
BYAAH85's Avatar
jl's new tr650csi are in my car right now and im very happy with them. running off my stock acura deck to and they still sound very clean. base is pretty impressive for 6.5s
Old Apr 27, 2008 | 10:18 AM
thekid03's Avatar
Default Re: Good 6.5" Component set or 2 ways. That have some moderate lows (BYAAH85)
well I ended up going with a pair of Alpine Type R's on the recommendation of an installer I met at Pasadena Auto Sound. Tweets will swivel up to 15 degrees and their soft-dome as well. It would really be nice to find a shop who has built a contraption to listen to car speakers mounted in a location that will be similar to the install loc in one's car.
Some type of booth/recreation of the inside of a car in which you can sit down and component sets or even subs are mounted on some ferris-wheel contraption and all that's needed to be done to listen to different speaks is rotate this ferris wheel contraption so the speaks you want to listen to are in a position that is similar to your planned install loc. It's not totally ideal but it'd be a hellava lot better than what you normally find i.e. one big wall of speakers where you've gotta squat, sit on the floor or stand on a step-stool depending on where the speakers you'd like to audition are installed
Old Apr 28, 2008 | 11:25 AM
mrmckie's Avatar
good choice..i was gonna say Alpine Type S..pretty good bang for the buck components w/ or without an amp
Old Apr 28, 2008 | 03:54 PM
guardian_ang3l's Avatar
You won't be disappointed in those Type-R speakers. I've been running those in my civic for about a year and I love them. I was very impressed by the amount of bass they have.
Old Apr 28, 2008 | 04:27 PM
94Hcivic's Avatar
Default Re: (guardian_ang3l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guardian_ang3l &raquo;</TD></TR><TR><TD CLASS="quote">You won't be disappointed in those Type-R speakers. I've been running those in my civic for about a year and I love them. I was very impressed by the amount of bass they have.</TD></TR></TABLE>
Old May 26, 2008 | 03:40 PM
JDMCRX's Avatar
Default Re: (94Hcivic)
So what did everyone end up going with ? Im thinking of the ORION hcc1 6.5 or a set of alpine type r
Old May 26, 2008 | 06:48 PM
rsxer63's Avatar
Default Re: (JDMCRX)
I am running Diamond Audio 6 1/2" components in my RSX and I will be installing Polk 6 1/2" components in my 87 Teg this week. I love the Diamonds but was unable to get the deal (budget system for the Teg) on em so I went with the Polks for the Teg. I installed some 6 3/4" Polk coaxials in the rear of the Teg and so far I am very happy with them (especially for the price).
Matt.D87
Audio / Security / Video
Mar 22, 2009 02:19 PM
ge_itr
Feb 23, 2007 05:17 AM
Shizznaz
Jun 28, 2005 01:57 PM
ieatrice
Jan 27, 2005 11:55 AM
itsmike
Nov 29, 2003 04:44 PM
