installing fmic with out cutting the bumper questions
Old Dec 15, 2007 | 09:30 PM
laocivic's Avatar
Default installing fmic with out cutting the bumper questions
well i got a ebay intercooler 27 wide 12 high 3 thick. its for an EG. i wanna keep it somewhat sleeper and mount it without cutting up the bumper. any ideas?
take off bumper support? (still want the car safe)
cut bumper support(safety?)
possibly cut just the back of grill (will it look ok?)
TIA guys
Old Dec 16, 2007 | 06:54 AM
97grnrs's Avatar
Default Re: installing fmic with out cutting the bumper questions (laocivic)
they sell smaller ones for that reason.. like 6 x 27 x 3 ... that one u got is big.. u have to remove bumper support.. in a crash that support aint gonna help.. its only meant for low speed impact very low speed.
Old Dec 16, 2007 | 07:35 AM
laocivic's Avatar
Default Re: installing fmic with out cutting the bumper questions (97grnrs)
oh ok thanks..im was just seeing if there were any tricks for fitment or anything.. i dont wanna use a smaller intercooler for my setup, but if i got to cut i will
Old Dec 16, 2007 | 07:50 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
you can still cut and make the bumper still look stock.... this is the precision and is 3in thick also... it took a lot of hacking and fitting but i made it fit...
you will either have to cut or take off the bumper support though since its 12inches high
Old Dec 16, 2007 | 02:25 PM
laocivic's Avatar
Default Re: (tannerLSt)
bump..also what did u guys use to cut it..i used a knife last time..it took forevfer. how bout a razor blade?
Old Dec 16, 2007 | 02:45 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (laocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote">bump..also what did u guys use to cut it..i used a knife last time..it took forevfer. how bout a razor blade?</TD></TR></TABLE>
Hand-saw, dremel, cutoff wheel, small reciprocating saw, sawzall. All better options than a knife.
Old Dec 16, 2007 | 02:46 PM
blinx9900's Avatar
how about a cutting wheel makes it really easy, and clean.
i honestly dont think you can keep your bumper support, you wont be able to have it high enough with it and it will either A stick out the bottom or B hit the ground over dips and such.
i have an apexi GT thats 11" tall and it barely fit behind the support, but i still removed the support, perhaps you grind the back of the support down, or cut it out, but then you have a big beam in front of your IC.
Old Dec 16, 2007 | 03:09 PM
laocivic's Avatar
Default Re: (blinx9900)
i used a dremel but the plastic got hot and it kinda like melted down and kept piling up and clogging sorta..if u know what i mean. i guess ill use a hacksaw or cutting wheel
Old Dec 16, 2007 | 04:29 PM
Tippyman's Avatar
Dremel with cut-off wheel or a sawzall.
Old Dec 16, 2007 | 05:20 PM
laocivic's Avatar
Default Re: (Tippyman)
i guess ill try the dremel but on different speeds til i find the right one. any other thoughts?
Old Dec 16, 2007 | 07:50 PM
laocivic's Avatar
bump anyone else?
Old Dec 17, 2007 | 04:33 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
the above picture i posted i used a dremel
Old Dec 17, 2007 | 06:23 PM
22boost's Avatar
Garrett 24"x8"x3.5"
<U>Belt sander</U> is the best way to go, takes it down pretty quick and even, just keep going back and forth...take a little off at a time. Mount the intercooler eyeball what you need to take off, sand, set bumper in place, repeat.
The intercooler you have is a little tall...bumper support will most likely have to go...and to use the entire intercooler you will have to cut up near the license plate bolts
Old Dec 17, 2007 | 06:41 PM
mitsuman's Avatar
Default Re: (22boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22boost &raquo;</TD></TR><TR><TD CLASS="quote">Garrett 24"x8"x3.5"
The intercooler you have is a little tall...bumper support will most likely have to go...and to use the entire intercooler you will have to cut up near the license plate bolts</TD></TR></TABLE>
WOW, super clean. Good job. Wanna do mine?
Old Dec 17, 2007 | 06:43 PM
nwshralper's Avatar
BUMP&gt; thats super clean man and i fit the greddy 30x12x3 in mine but it took alot of moving around and cutting
Old Dec 17, 2007 | 06:55 PM
22boost's Avatar
Default Re: (nwshralper)
All you should really have to do is center the intercooler left/right, then adjust up/down to try to line up the chargepipes so the fit just between the bottom of the side 'grilles' and the bottom of the bumper. Im using 2.5" chargepipes.
<U>Make sure your charge pipes are installed w/clamps</U>, if your using T-bolt clamps you may have to rotate them in a way that when the bumper is pushed back on its not catching.
Modified by 22boost at 7:38 AM 12/18/2007
Old Dec 18, 2007 | 09:55 AM
laocivic's Avatar
is there anywhere i can rent a belt sander? i dont feel like buying one lol.
Old Dec 18, 2007 | 11:53 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote">is there anywhere i can rent a belt sander? i dont feel like buying one lol.</TD></TR></TABLE>
Highly doubt it, there pretty chap at harbor fright bro.
fastlude69
Jul 14, 2007 08:49 PM
slowcrxsib16
Jul 25, 2006 02:36 PM
june
Jan 31, 2005 10:30 PM
sporkcrx
Sep 5, 2003 09:42 AM
97itr86
Aug 21, 2003 07:13 PM
