h22 swap problems
Whats good?
I got a 1995 Accord. I had a JDM h22 swapped into it like a year and a half ago. The problems started to add up a few months ago when I was due for CT emissions. I knew the guy had screwed me over on the swap about a year after he did it. It was a hack job and he messed up a bunch of things. So now I fail emissions cuz the motor is all hooked up right. I got a brand new exhaust and it helped bring the numbers down but I still failed the second time. The shop that did my exhaust said the wiring harness wasn't all attached right but it was too big (and too expensive) for them to do at that point in time. My question to you guys is, does anyone know of a good shop that has experience with Honda motor swaps... specifically h22's in my year accord. I want someone who knows what their doing to look at it and tell me what I need done. I know its gonna cost me a hell of a lot of money but I just want a nice clean running motor that passes emissions tests. So if anyone knows a good shop in CT, southern Mass., NJ, or NY please let me know.
Thanks.
Thanks.
well if you also have wiring issues have RYWIRE rebuild your harness, send it to them and as long as you have all of the right connections, there shouldn't be any problems, 3-5 day turnaround and they do excellent work!
thats the problem, i'm not sure which harness he used. the idiot left a bunch of the things unplugged... I assumed it was the harness for the f22 and the unplugged connectors were for the automatic tranny and other things for the f22 that didnt connect to the h22. Wish there was a place that made the harness without requiring me to send mine in... but i havent found one.
hey CR-V-Tech,
If i buy a new USDM harness and send it to rywire, does it have to be from my year?(95) or will any 90-97 harness work. On the Rywire site it seems to say that they can take any 90-97 and modify it for any 90-97 swap... but its not definitive.
hi i have a 94 accord with an h22 swap as well emmsion test pretty much you have to pay under the table for it cost me about 150 each time good luck
well if you need a stock h22 harness i will have one like next week but its a 97' so if that will work let me know and i can sell it to ya. It should cause once you tell them your application they will build your harness to spec! Better yet i'll be in oceanside, ny from the 24th to the 2nd, if you want i could bring it out with me! let me know i'll pm you my phone #
Modified by CR-V-tech at 12:12 AM 12/20/2007
And Thanhtruong, the emissions tests in CT arent as strict as cali. I actually didnt fail that bad with my new exhaust. I know once the engine is tuned and running right it'll pass.
it'll cost you $250 maybe less and they will build it to your spec, just tell them what car, motor, distributor as well as the ecu and they will hook you up! let me know before sunday night cause i'm flying out of kansas city at 7am monday morning! most obd1 and obd2 plugs interchange, with the exception of dizzy, injectors and the main ecu plugs, secondly the part that lays over the valve cover and looks pretty is on my harness too! just let me know, thanks
low13da9
Mar 18, 2012 09:59 PM
PolarMan90
Aug 11, 2008 03:50 PM
