Lighting HID/Xenon kits, Retrofits and Associated Topics
No tailights? I need toggle switch solution
Old Dec 15, 2007 | 02:42 PM
meotch's Avatar
Default No tailights? I need toggle switch solution
not for a honda... for my beater delta 88. checked the bulbs, fine, replaced anyways.. nada voltmeter.. nada..
so, could I possibly just tie the ajoining wires together and spit off a 12v source on a toggle switch? this car is really ghetto. the headlights are on a toggle right now.. lol.. but im not sure how rigged it is... anyways, thanks in advance for any insight.
cheers,
-mitch
Old Dec 16, 2007 | 03:43 PM
Padawan's Avatar
Darth ModerVader
Default Re: No tailights? I need toggle switch solution (meotch)
Do the brake lights work?
Old Dec 16, 2007 | 07:39 PM
meotch's Avatar
Default Re: No tailights? I need toggle switch solution (Padawan)
yeah, sorry, brakelights and hazards work... taillights, driving lights and dash light are gone.. I can deal with no cluster light, but its hard enough to bring chicks home in a beater car.. let alone one you can only drive at night with the hazards on
Old Dec 16, 2007 | 07:44 PM
Padawan's Avatar
Darth ModerVader
Have you checked the fuses? Do your front parking lights work?
Old Dec 16, 2007 | 07:47 PM
meotch's Avatar
checked the fuses, this all came about after crashing into my friend at work (on purpose, the beauty of >$500 vehicals). im just looking for the ghetto solution, I dont want to get into the schematics of it, lol just a quick fix
Old Dec 16, 2007 | 07:48 PM
Padawan's Avatar
Darth ModerVader
Again, do your front parking lamps work?
Old Dec 16, 2007 | 07:58 PM
meotch's Avatar
there are no driving lights at all, just the highs an lows off the toggle
Old Dec 16, 2007 | 08:17 PM
Padawan's Avatar
Darth ModerVader
You may want to check the factory lighting relays (usually under the hood). If there are no problems with those, then I think your best/easiest solution would be to run new wires to the lights, attach them to a relay off the battery, and use your own switch. Otherwise, you'll have to go through and diagnose the existing wiring.
Old Dec 16, 2007 | 09:29 PM
meotch's Avatar
cool thanks man, the relay was kind of what I was worried about, im just going to rig it up, see if it works, gas is the only money I justify putting into the car.. lol
cheers,
mitch
rrepking
Jan 6, 2015 02:08 PM
TanaVP
Lighting
Sep 2, 2014 03:46 AM
cebucivic
Aug 8, 2010 09:07 PM
accord99power
Jun 16, 2008 05:39 AM
JSpekBB4
Aug 29, 2006 09:56 PM
