Car wont start!!!!
Old Dec 15, 2007 | 01:08 PM
90cb7tuner's Avatar
Default Car wont start!!!!
Well im having a problem my car wont start. I have charged the battery and its full so i put it back in my car and still nothing happen's no light's or anything turns on.
Thanks
Ronnie.
Old Dec 15, 2007 | 02:25 PM
hondadude's Avatar
Default Re: Car wont start!!!! (90cb7tuner)
under hood main fuses okay? Do you have a test light so you can do some simple checks?
Old Dec 18, 2007 | 03:49 PM
90cb7tuner's Avatar
Default Re: Car wont start!!!! (hondadude)
1990 Honda Accord LX, Everthing is pretty much stock.
Old Dec 18, 2007 | 06:58 PM
91ex's Avatar
pop off your main fuse panel, passenger side close to the firewall. the first fuse there is a big 80 amp black fuse. thats probably the problem. be careful though the screws in that fuse are VERY easy to strip.
if thats not it check your grounds. there is a small ground from the battery terminal over to the pass. side frame. its about 6 inches long. if im thinking correctly this is vital. make sure its got a good connection first.
91sedan_kid
Jan 19, 2025 09:13 PM
fredo818
Feb 3, 2013 06:27 PM
#1 Dominican
Dec 27, 2008 12:50 PM
LudeNsoL
Nov 19, 2007 08:55 AM
b20vtecEK
Apr 5, 2005 11:45 PM
