96 itr tranny into b16a2? what are some possible pros i could be looking for?
Old Dec 15, 2007 | 12:53 PM
pli's Avatar
pli
Default 96 itr tranny into b16a2? what are some possible pros i could be looking for?
so im thinking about an itr tranny into a b16a2. it is possible right?
im also curious..96 itr tranny came with lsd right? ..and the itr tranny that i might be looking to get has 4.785 final drive in it.
what could be the pros and cons about doing this tranny swap? i currently have a b16a2 tranny on mines.
Old Dec 15, 2007 | 01:25 PM
hatchling37's Avatar
Default Re: 96 itr tranny into b16a2? what are some possible pros i could be looking for? (pli)
Yes, it'll bolt right up. It's obviously hydraulic, so no worries there.
Well, you already mentioned the pros. Higher final drive and LSD.
Only con I can think of is, it might not have an LSD in it. I don't think all ITR's came with a factory LSD. I might be wrong, though. Just look inside the differential when you see it and make sure it doesn't have the pin holding the spider gears in place. It will look hollow.
Old Dec 15, 2007 | 01:50 PM
BlueIntegraBoy's Avatar
The 98 spec ITR tranny had the 4.785FD. The 96 spec ITR tranny has the same gearing as the B16 tranny plus LSD with a 4.4FD.
All Type-R trannies have LSD.
Old Dec 15, 2007 | 01:55 PM
95dxsir2's Avatar
Default Re: 96 itr tranny into b16a2? what are some possible pros i could be looking for? (BlueIntegraBoy)
cons, gas mileage on the freeway is down, but i don't care.
Old Dec 15, 2007 | 02:07 PM
black_EM1's Avatar
Community Builder
Community Influencer
With the 96 Spec tranny, you only gain an LSD. Which is actually alot.
If you're looking for the 4.785FD, you need to find a 98+ Spec ITR tranny.
http://www.allmotorhonda.com
Look under transmissions in case you want to know the exact gearing.
spintboy
25
Sep 15, 2007 01:52 PM
emotionisdead
Aug 30, 2005 01:33 PM
Nicram
Aug 7, 2005 08:48 AM
TodaR
Apr 12, 2003 02:39 PM
HybridGSR1
Oct 9, 2002 02:52 PM
