kaaz lsd install help vechile sensor not working
hey i bought a kaaz lsd from a friend of mine for a gsr, , i can not get the stock vechile sensor the rod to go in fully, do i need from the kaaz, or what? heres a pic of the stock one, so my question is do i need a different one?
My Kaaz (for a Prelude) came with a new VSS gear as the speedo gear ring teeth were cut differently in the Kaaz than the stock H22 speed gear ring teeth.
You might want to contact Kaaz to see what they say. I suspect your GSR LSD is going to need another VSS gear like my Prelude Kaaz LSD uses.
NstyGrnHatch
May 25, 2006 02:37 PM
