p0411
hey guys..im getting p0411 (Secondary air injection) i had to remove the intake when doing a clutch so i most likley crossed the lines installing it..ive tried both ways still nothing..does anyone know exactly how they go..or if you could please run outside and look i would apprecaite it..ive searched for pics and diagrams couldnt find anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matthevelli »</TD></TR><TR><TD CLASS="quote">hey guys..im getting p0411 (Secondary air injection) i had to remove the intake when doing a clutch so i most likley crossed the lines installing it..ive tried both ways still nothing..does anyone know exactly how they go..or if you could please run outside and look i would apprecaite it..ive searched for pics and diagrams couldnt find anything.</TD></TR></TABLE>
also, check to make sure that your air pump hose does not have a kink in it. if it does, the cel will come up. this happened to me. after you're done, you should use an obd2 scanner to erase the codes on your ecu.
yeah i checked for kinks..i noticed the lines to get crimped a little when you place them in the clamps..could that be it..i wouldnt think so..i cleared the code and gave me friend my scanner so if is light pops up he can check it..let me know if its the same code
i had this cel also when i added an intake on my s. there are i believe 2 or 3 little hoses very small grey ones. it got over looked by the fuel rail between valve cover and intake. it will fix it no prob
MR aK
Honda S2000
10
Oct 2, 2008 04:34 AM
Scrapin4DR
34
Dec 5, 2005 06:18 AM
