4 lug rear disk brakes
I know that you may say this has bin covered. but here is the thing. i got the ep3 e brake cables but all of the thresds say they should be to short. mine are to long by like 4 inches. any ideas of what i could do.
they will still work, i've had both rsx and civic si ebrake cables...
you just have to keep messing with it, it'll fit eventually. taking the ebrake handle assembly off helps too. also put the lines in first before putting the 10mm brackets back in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">they will still work, i've had both rsx and civic si ebrake cables...
you just have to keep messing with it, it'll fit eventually. taking the ebrake handle assembly off helps too. also put the lines in first before putting the 10mm brackets back in.</TD></TR></TABLE>
Listen to this wise man.
i know me 2. i have them hooked to the e brake handle already, but then when i go to put them on the brakes in the rear its allready fully retracted and are too long by liek 4 inches. liek its overshooting the hook up area. and yes all brakets are in place
yes i ran them right and they are to long i don't get it. ima try something Thursday night that may work. and you cant use drum brake cables u cant attach them
. sorry man. maybe post some pics?
