Ecu Question
Old Dec 15, 2007 | 11:47 AM
kato_si's Avatar
Default Ecu Question
I have an 00 si with b16a2. headers.. exhaust. and intake. Had a question about chiped ecu. Basically what i want to ask is if when its chipped they have the revlimiter sit to 8500.. i always shift before or at 8000(when racing).. now i assume it wouldnt be good to shift above 8000 rpm would it never shifted above. and for a 2 step rev limit for those who own em1s what are is your set at? what will be a good setting for the 2 step. thanks-
Old Dec 15, 2007 | 07:19 PM
z6hatchboy's Avatar
I can sort of answer the first question, when its chipped they can set it anywhere they want. If its someone reputable or knows a little bit about cars, they probably kept it realistic at around 8500.
Old Dec 15, 2007 | 07:33 PM
YABUDDY's Avatar
Default Re: Ecu Question (kato_si)
Its a honda. Its not gonna hurt a thing to take it over redline. My boosted d 16 redlines at like 7,200 and I take it to at least 7500 all the time when i race. I have a chipped ecu from phearable and the check engine light comes on as a shift light at like 7500.
Old Dec 15, 2007 | 07:56 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Ecu Question (EG95EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG95EX &raquo;</TD></TR><TR><TD CLASS="quote">Its a honda. Its not gonna hurt a thing to take it over redline. My boosted d 16 redlines at like 7,200 and I take it to at least 7500 all the time when i race. I have a chipped ecu from phearable and the check engine light comes on as a shift light at like 7500. </TD></TR></TABLE>
There's a huge difference between 7500 and 8500 RPMs bro.
Old Dec 16, 2007 | 08:00 AM
kato_si's Avatar
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">I can sort of answer the first question, when its chipped they can set it anywhere they want. If its someone reputable or knows a little bit about cars, they probably kept it realistic at around 8500.</TD></TR></TABLE>
would it be safe to shift at 8500 rpm without damaging anything on the motor?
Old Dec 16, 2007 | 08:18 AM
97Ej6mike's Avatar
Default Re: (kato_si)
EDit, : blah, nvm.
Modified by 97Ej6mike at 12:08 PM 12/16/2007
Old Dec 16, 2007 | 09:12 AM
Ron454321's Avatar
He has an internally stock B though. Chances are when you try to shift at 8500 you are gonna hit the rev limter by accident, I would set the shift light a little lower, if you have one.
Old Dec 16, 2007 | 11:11 AM
kato_si's Avatar
Default Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 &raquo;</TD></TR><TR><TD CLASS="quote">He has an internally stock B though. Chances are when you try to shift at 8500 you are gonna hit the rev limter by accident, I would set the shift light a little lower, if you have one.</TD></TR></TABLE>
yea. what i want to know if shifting over 8000 rpm would be safe for my engine? and not damage it.. cause i have not try going over just want to make sure.
em1_fox
Dec 20, 2007 07:00 PM
Layziebtnh055
Apr 6, 2004 08:22 AM
a2nvi3tboy
14
Dec 16, 2003 01:25 AM
