95 accord 2.2 single cam vtec
ok my cousin has a 2.2 what I need to know is when is vtec supposed to activate and what is the rev limiter.
I dorve it and it doesnt feel like vtec is activating and it is red lining at 5500rpms. no cels either.
I am on a diffrent name now the car bounces off the rev limiter at 5500 and wont rev any higher there are no cels and I just did an oil change today thinking that maybe it was the oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowRSX »</TD></TR><TR><TD CLASS="quote">ok well what is the rev limiter supposed to be?</TD></TR></TABLE>
6750
6750
its not limiting it at 5500, its an analog gauge, so it has to spool up to the actual rev limit, but since its bouncing off the rev limitier it cant get there before the limiter slows the r.p.m. down, so it shows it at 5500 but its actually at 6750, if you have access to a scanner with real time data stream like the snap on scanner or a matco scanner, you'll see what im talking about, since the data stream is a digital input and not analog like the dash guage. as far as the solenoid kicking in for the v-tec, it doesn't open until 3500 r.p.m.s under 75% or more load. you'll see that too with the scanner, i never realized that you could actually accelerate without switching into v-tec until i did a test drive with a customers car and the had the scanner running. so if you want to go fast its full throttle or nothing at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">I am on a diffrent name now ...</TD></TR></TABLE>
why are you posting from two different names?
is it an auto? cause if you're just revving it in park, it won't let you get into vtec just sitting there. it will bounce off the vtec threshold. i have a 98 2.3 vtec 5 speed and i usually don't hear vtec kick in until around 5500, so that may have something to do with it.
Its a 5 speed and you can go down th road and floor it and it will sit thr and bounce off the limter at 5500.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">
why are you posting from two different names?</TD></TR></TABLE>
I was at my buddys house its actually his cousins car
khronicboy420
Oct 9, 2010 09:56 PM
